Special offer on receiver hitches: Torklift Outlaw Series Debuts
Torklift International is proud to manufacture the safest towing equipment that specializes in high capacities and durability. The engineering team at Torklift invests in rigorous testing and advanced technology to create professional grade towing equipment that you can trust.
When it comes to towing a trailer safely, it’s important to know towing basics. Click here to read about common towing myths. One of the most important aspects of towing safely is becoming familiar with weight capacities and limits of your vehicle, towing equipment and trailer.
The number one cause of trailer hitch failure and roadside trailer accidents is overloaded tongue weight. This is the weight from the front of your trailer pushing down on your tow vehicle with cargo, axle, tanks and more.
Exceeding trailer tongue weight is dangerous
Overloaded tongue weight or “vertical load” causes trailer hitches to break and also has severe negative effects on the truck's ability to steer and maneuver safely due to off-balance weight. Click here to learn about the importance of tongue weight and weight distribution.
To address weight concerns Torklift International has taken the lead in the towing industry with the SuperHitch Outlaw Series. The Outlaw Series features the highest rated receiver hitches and towing accessories available.
SuperHitch Outlaw Series includes:
In most states it’s against the law to exceed maximum tow weight rating of your vehicle. There is no question about elevated safety hazards and it also makes you liable in the unfortunate event of an accident. It is also likely to void any warranty or insurance coverage. We strongly suggest staying within the maximum weight capacities set by your vehicles’ manufacturer.
No need to worry with the SuperHitch Outlaw Series
When used with weight distribution, we offer receiver hitches that handle an incredible 3,000 pounds tongue weight capacity and 30,000 pounds towing capacity. It’s best to have the SuperHitch Outlaw Series on your side.
There are a few reasons that set SuperHitch receiver hitches apart from other towing hitches.
#1)High capacity towing
When used with a weight distribution system, the SuperHitch exceeds high capacity towing needs with unique patented designs for half-ton through 1.5-ton trucks.
SuperHitch Hero 15K
SuperHitch Original 20K
SuperHitch Magnum 30K
*When used with weight distribution system
#2) Reinforced hitch pin locations
The hitch pin location is where a ballmount adapter would be attached and secured with a pin. From there, the trailer tongue is connected. It’s common to experience wear and elongation known as ‘egging’ at the hitch pin location from excessive towing. The elongation causes jerking which leads to increased distortion and damage.
Top: Evidence of elongation or egging on hitch pin location
Bottom: Reinforced hitch pin locations on SuperHitch
You won’t find the effects of elongation on a SuperHitch. Every SuperHitch has reinforced hitch pin locations to prevent this from occurring.
#3) Dual Stacked Receiver
Not only does the dual stacked hitch receiver design allow for outstanding strength, but it also gives you the freedom to tow accessories in the upper receiver. This includes cargo trays, bike racks, or carriers for generators, motorbikes, kayaks, etc.
Dual 2-inch receiver hitch design
If you plan to tow while hauling with an overhang from a truck camper, the dual receiver fits perfectly with the dual-channeled SuperTruss towing extension. With models that reach from 21 to 60 inches, check towing extension capacities here.
Towing a boat with truck camper overhang requires a receiver extension
The Torklift Advantage
Built in the Unites States, all receiver hitches featured in the SuperHitch Outlaw Series are covered with a lifetime warranty. Most applications do not require drilling and bolt directly to the truck frame. Compatibility is simple with industry standard 2-inch by 2-inch receivers on both top and bottom.
Torklift customer Jim Weber uses the SuperHitch and SuperTruss for towing a trailer while his truck camper is loaded on his truck.
He shares his experience here:
Deal on Torklift SuperHitch
To kick off a special offer this summer, buy a SuperHitch and get a $20 factory mail-in rebate on either a HiddenPower under vehicle battery mount or ExtendedPower mountable battery tray. Take advantage fast! The SuperHitch deal is available from June 16 - August 16, 2015. Intended for retail consumers only, proof of purchase must be provided to redeem the mail-in rebate through Torklift International.
Click here to learn more about the SuperHitch Outlaw Series.
For additional information and details on this offer, read the rest of this article by clicking below.
Follow us!
- Receiver hitches
- Receiver hitch extensions
- Weight distribution system
- Wiring harnesses for towing
- Pintle hook and ballmount adapters
SuperHitch Hero 15K
- Designed for half-ton trucks including Ford, Dodge, Chevrolet, Nissan and Toyota
- Rated at 15,000 pounds towing capacity*superhitch-towing
- Tow like a pro with SuperHitch
- Rated at 1,500 pounds tongue weight*
- Find applications here
- Rated at 20,000 pounds towing capacity*
- Rated at 2,000 pounds tongue weight*
- Rated at 30,000 pounds towing capacity*
- Rated at 3,000 pounds tongue weight*
Follow us!
__________________
Torklift International – Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
04-19-2018 02:59 PM
Torklift Sheryl
09-28-2017 07:06 PM
Torklift Sheryl
06-08-2017 06:32 PM
Torklift Sheryl
09-03-2015 03:48 PM
Torklift Sheryl
08-19-2015 01:44 PM
