More UVC harness Questions
I have a 96 F250 Powerstroke. 115K miles Engine started misfiring randomly and then clears up and repeats this a couple times every few miles. Check engine light goes on during misfires. I'm thinking its the valve cover harness or connectors. I haven't tried my code reader but it may not be the right one. Is there a "shade tree" mechanic way to determine which bank is misfiring? Thanks.
I unplugged the connector while running and that identified the bad area for me. Mine actually broke the wire at the connector for the glow plug and the wire was intermittently shorting out. It was a mess to diagnose because it would run fine while the GP relay was on and then fall to pieces after. Initially, though, I had some symptoms like you describe. If you can afford it, definitely go with the Ford UVCHs in my opinion.
I had the IDM go bad on my truck about 6 months ago. I did not have the equipment to test the IDM so I had to verify everything else worked before I put the 800 bucks into a new one. The IDM is placed in a bad place. Its located on the driver side fender out in the elements you pick up off the road.
With that being said I will try to remember how I narrowed it down to the IDM in the first place.
I will note that like lindstromjd said check your oil. It is imperative that you keep up on oil changes, and levels with these trucks.
I haven't had to time to try to fix this yet. I'll definitely check the oil level first. My code reader of course couldn't read the codes. At idle it sounds perfect, so pulling the connectors at idle wouldn't tell me much. Last time I had problems with this thing it was the CPS and damm it took me a long time to diagnose it, these powerstrokes are a PITA to diagnose a problem when they run bad. Hopefully tomorrow I'll get to work on it. After the oil check, I'll start checking the valve cover wiring.
And it's not about how the wiring looks physically, it's about how it performs under a voltage test.
Furniture Doctor
05-08-2016 10:25 PM
gibbons1
08-18-2013 08:39 AM
BigCajun54
01-29-2007 09:14 AM
Drover
04-14-2005 10:36 PM
