Slight leakage in rear glass weatherstrip?
Hi!
I noticed a tiny leakage in the rear glass weatherstrip when it's raining. I inspected it, and it looks fine so I attempted to clean it and the glass, but it didn't help. Is this a common thing? What's the best to use for cleaning and renewing the seal?
I guess maybe the rubber is getting too hard to seal well, and if that's the case I guess the only cure is a new weatherstrip...
'05 Expy EB 4x4
'05 Expy EB 4x4
I live in Norway, and no such thing as a blazing sun here.
I removed weatherstripping, and slightly bent where it mounts with a rubber hammer. It was enough to keep water out. A quick google search shows that many has this problem.
Hey! A fellow Norwegian! I'm from Norway as well, I just happen to live in the Philippines..
I think I found my problem though. When looking more closely today after I found the issue with the paper test last night, in daylight it's evident that the rear glass isn't sitting right, it's sticking out a bit in the top, and it's worst on the drivers side. And it looks like the hinges are slightly bent out of shape, and the one on drivers side is worse then the other one. I guess that means I have to look for a new pair on ebay.....
