trailer hitch
trailer hitch
so, how strong of a bumper pull hitch can I put on my 05 F350 DRW? My other F350 DRW has a steel flatbed with a real stout receiver and I have a 15k ball, but this 05 has a regular bed and came with a receiver that says it's limited to less than 10k unless I get a load-balancing hitch. Can I replace this receiver with a stronger one? Maybe I have to buy a real stout bumper with integrated hitch?
You can get a heavier hitch, heck I have a 16k on my F250, but the weight distribution caveat is the same. It's not the hitch itself that requires the WDH, it's the truck overall. It's simply not designed to carry more weight than that just on the hitch ball. Think about the leverage 1000-1500 pounds of tongue weight places on the rear suspension when it's on a trailer hitch 4' behind the axle center line.
SuperHitch Truck Receiver Hitches | SuperHitch Hero 15K | SuperHitch Original 17K | SuperHitch Magnum 30K | Torklift International
SuperHitch is designed to handle the highest towing capacities of today’s trucks. It sounds like the SuperHitch Original 20K or SuperHitch Magnum 30k might be a good fit for you depending on what you plan on hauling.
__________________
Torklift International – Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
You should always stay within your truck’s tow weight ratings and make sure that your trailer hitch is rated to haul at least as much weight as your truck is. Have you had a chance to look at SuperHitch?
I put an 18,000lb trailer capacity (WC or WD), 2000/2500lb tongue weight (WC/WD) hitch on my dually. It's a 2 1/2" receiver. Matching draw bar and high rated ball. I tow a 14k/lb dump trailer which, if full, would be at my towing limit. Most loads would be 7-10,000lbs. So well within the rating on the hitch. I had the factory 2-1/2" hitch but the weight carry was something like 8000/800 trailer/tongue so I wanted to upgrade.
I have no ideas of the legalities of this but I like knowing the hitch/receiver is rated beyond my trailers capacity.
I believe this is the one I have. You may need more depending on needs. If I was loaded to near max all the time I'd really look into a WD hitch. I just don't know how those would work with constantly varying loads vs the constant weights of travel trailers.
http://www.etrailer.com/Trailer-Hitch/Draw-Tite/45293.html
Titan Trailer Hitch Receiver - Custom Fit - Class V - 2-1/2" Draw-Tite Trailer Hitch 45293
I have had multi 5W hitches and, currently the B&W Companion. The biggest difference is no yanking the handle trying to get it released to disconnect. The B&W can be opened with a couple fingers, just move the handle forward, done. If for any reason it does not release immediately there is a hole to pin the handle in the open position, pined the jaws can not stay shut. I have had to do this one time in about 30,000 miles of towing.
Wrong thread, or something...
I have 2004 F350 and pilling 14,000 5th wheel with bw companion hitch and love it! This is not the sliding hitch. I built a cart so I can slide the hitch right out of the bed onto it; it’s still a bit heavy though but very well built and comes apart in two pieces to lighten the work load if necessary.
Siriustoo
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
01-23-2017 01:27 PM
Bigdawg5565
19
02-04-2016 07:10 AM
mgm5555
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
03-09-2004 11:01 AM
