Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Ford V6 > 3.0L V6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 07-29-2003, 08:38 PM
davidism davidism is offline
Garage is empty, add now
davidism is starting off with a positive reputation.
Need Help - 99 Ford Ranger 3.0 Firing order
Anyone?
Thanks in advance.
  #2 (permalink)
Old 07-29-2003, 09:59 PM
Another question, what could potentially happen if you tried to start up a vehicle with the firing order backwards?
  #3 (permalink)
Old 07-29-2003, 10:28 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a name known to allRockledge is a name known to allRockledge is a name known to allRockledge is a name known to allRockledge is a name known to allRockledge is a name known to all
Cylinder Numbering (front to rear): Driver's Side 4-5-6; Passenger Side 1-2-3.
Base timing: 10 degrees BTDC (non-adjustable).
Firing order: 1-4-2-5-3-6.
Also, keep in mind that the EDIS ignition on the 3.0L vulcan fires the 1 and 5 cylinders at the same time, the 2 and 6 cylinders at the same time, and the 3 and 4 cylinders at the same time. The reason for this is because the 1-5 plugs are in series, as are the 2-6 plugs and the 3-4 plugs, respectively. Here is a nice diagram of that (thanks to Bob Ayers for providing it):
__________________
'98 Ranger XLT 4x4 (4.0L)
'97 Taurus GL (3.0L Vulcan)
'94 Taurus SHO (MTX)
Ford Pics
  #4 (permalink)
Old 07-29-2003, 11:05 PM
Thanks for the info Rockledge. I just wanted to double check this. I had it wrong the first time, started it up, ran it around the block and it was misfiring. Figured I had the wires on wrong (I apparently did not pay close enough attention when putting them on the first time). Now, it is still running very rough even with the wires on correctly (no more misfiring). Could I have possibly damaged the plugs or wires again? Maybe something worse?
Tags
30, 30firing, 30l, 3l, 94, 98, 99, diagram, fire, firing, ford, order, ranger, v6, vulcan
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
