1993 Ranger clicking from front end. CV joint?
I have a 1993 ranger (3.0l, 4x4 with lockouts, stock wheels). Clicking noise started coming from the front driver side about a week ago. Sounds like a CV joint but I'm not 100% sure. Gets quiter when cornering. I had the driver front wheel off a couple days before it started and the lock out came off with the wheel. I took it off the wheel and put it back on the truck so it wouldn't get crap in it. Could I have rotated it and that's what's making the noise? Or is it a coincidence and it is a CV joint? I don't have the money to have a garage look at it (most places around me charge for diagnosing). Has 163,500 miles and less than 2,000 miles on front wheel bearings
I would first make sure the hub is working properly. Jack up the front driver side tire so it's off the ground and can spin freely. Make sure hub is unlocked and spin the tire by hand. See if the axle shaft turns with the wheel (it shouldn't). Then lock the hub in, spin the tire again and see if the axle shaft turns (it should). If the hub works properly, that wuold obviously eliminate that as a possibility, and it would also eliminate the u-joint on the axle shaft, since that doesn't spin or do anything when the hub is unlocked.
If that checks out the problem is probably a wheel bearing or possibly something wrong with the brake assembly.
I did as you said, took the wheel off. Lockout works fine when in free it doesn't turn the axle, when in lock it turns the axle and driveshaft. But, with both lockouts in free I can turn the drive shaft by hand and it'll turn the axle but not the hub and make the clicking sound, when I lock in the hub the clicking goes away. I drove it with both lockouts set to lock and it made the clicking noise which doesn't make sense as to why it won't do it with the wheel off. Like I said wheel bearing are brand new and it can't be the brakes because it doesn't click when I turn the wheel by hand while on a jack.
Brett W 55 Ford
1999 to 2016 Super Duty
15
03-03-2012 04:52 PM
weldboy
01-16-2004 05:56 AM
