I need some help
I need some help
I have an old 72 ford it is a 3/4 ton. My dad use to drive it but parked it because of a leak in the fuel pump. I bought a new fuel pump and put it in. Changed the battery and everything and i got it running for a little while but it still needed work. I went out this morning and was tinkering with it again and the battery is dead and I made sure the key was off along with all the lights and everything. Any ideas on why the battery went dead?
Battery could still be good but the cables/terminals are shot. Put a voltmeter on the battery and measure. What ya got?
Clean all contact points in the start circuit, including grounds, reseat/tighten, and try again.
Otherwise, it'll be a parasitic drain... I have gone so far as to remove fuses to ID the culprit circuit.
'Could also try jumping the S terminal to the hot side of the battery to see if it cranks. If it does, then the problem is with the solenoid or ignition switch/wiring.
I like to keep a spare start solenoid onhand because it is one of the weakest links with these old trucks.... quality in manufacturing isn't what it used to be.
on
on
Most 40yr old battery cables should be replaced. Even tho they look good at the ends as they corrode inside where it can't be seen that reduces the current flow to the starter.
With all doors closed, lights off & Ign-switch off you should not have any little spark when placing battery cable onto the Battery.
Orich
Orich
Orich
Orich
