Vendor Specials, Discounts, Product Announcements & Group Buys This is the place to check out offers from FTE sponsors. Non-sponsor vendors may not post here.
Science behind the StableLoad Suspension Stabilizer
Old 06-16-2015, 11:06 AM
Torklift Sheryl's Avatar
Torklift Sheryl
Torklift Sheryl is offline
SPONSOR
Have you ever watched the TV show Mythbusters on the Discovery Channel? One of the oldest and most popular television shows on Discovery, the television series tests validity of rumors and myths by applying scientific method. With their experiments, the ultimate truth is exposed and common myths are debunked.
In an effort to reveal the capabilities of Torklift International StableLoad suspension upgrade we too, turned to science. In our own version of Mythbusters, we conducted a series of tests to address an important question:
Do suspension upgrades actually work?
We loaded a 2015 Ford F150 truck with 2,800 pounds to simulate significant payload. For an in-depth assessment, the loaded Ford truck is tested through three different variables that replicate common handling issues.
Large pot hole = side-to-side sway
Speed bump = porpoising (front-to-back motion)
Cornering = body roll
To measure degrees of movement, an inclinometer was mounted to the Ford F-150 truck. The inclinometer measures horizontal and vertical tilt.
The Ford truck was driven through the course to uncover the best and most effective suspension upgrade for your vehicle. To set a baseline, we recorded measurements of the factory suspension with no suspension upgrades. Second, we installed airbags at 100-psi air pressure. Finally, we put the StableLoad Suspension Stabilizer to the test.
The results may surprise you.
Take a look:
The outcome of our test relied on science to prove StableLoads as the clear winner. Torklift’s version of Mythbusters showed that suspension upgrades actually do work, and that StableLoads have the greatest affect on handling characteristics of a vehicle when it comes to side-to-side sway, porpoising and body roll. If you often use your truck to haul or tow heavy payload, the StableLoads should be the first suspension modification to consider.
To read the rest of this article, visit our blog by clicking below.
Follow us!
__________________
Torklift International – Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
Old 06-16-2015, 09:49 PM
heymrdj's Avatar
heymrdj
heymrdj is offline
That's a 2014 F-150 from U-Haul. Not sure that U-Haul is using a 2015 F-150. I've seen 2015 Seirra trucks though, and Transit 150's.
Torklift Sheryl
09-12-2017 03:18 PM
Torklift Sheryl
09-27-2016 05:48 PM
Torklift Sheryl
08-18-2015 11:49 PM
Quick Reply: Science behind the StableLoad Suspension Stabilizer
