8ft bed and bolt question
Hardware stores tend to not have automotive bolts....I am sure you could replace them with something similar from a hardware store though...
Autoparts stores and aftermarket stores should have them though...
http://www.ebay.com/itm/1999-2015-Ford-Super-Duty-OEM-F-250-350-Pickup-Bed-Bolts-and-Clips-/271904268138?hash=item3f4ec1df6a&vxp=mtr $70
http://www.ebay.com/itm/1999-2014-Ford-Super-Duty-F250-F350-pick-up-bed-bolts-and-clips-NEW-TAKEOFFS-/131537692887?hash=item1ea041e8d7&vxp=mtr $60
Way, way easier to install also. No more crawlling under the truck to take the bed loose.
The problem with the OEM clips/nuts is they are not really nuts. They are soft metal designed to allow the bolt to cut threads into them. Look it up. That's great at the factory from an assembly standpoint. However, when you go to DIY or take it apart, you need air tools to actually get them moving; hence, the breakage. I'd much rather crawl under my truck with a wrench to hold a grade 8 nut still while a helper loosens 8 bolts than fight with trying to unstuck the super duty bolts (been there, done that!).
Finally!!. Someone else who has had to REMOVE them
