7.3 IDI front driver-side lift point
OK,
I used four, also.
I made a bracket for the front/driver-side out of angle. I just used one manifold bolt (using the stock bolt which came with the engine), and it seemed to work fine.
As a side note: 2-ton Performance Tools lift with a Neiko 8-ton ram worked fine (using the 2-ton arm extension setting)
I used four, also.
Thanks. I have come to the conclusion the holes are used for several purposes in various trucks and vans.
rangergirl94
05-22-2012 06:10 PM
BombThreat
02-02-2008 04:03 PM
