1978 Crew cab 4x4 rear suspension help needed - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign In
Register Forgot Password?
Old 06-15-2015, 04:43 PM
DaytonaTunnel's Avatar
DaytonaTunnel DaytonaTunnel is offline
DaytonaTunnel is starting off with a positive reputation.
I'm not having any luck getting bushings for the rear suspension of my 1978 Crew cab. Wondering if anyone can lend a hand. I after Black Urethane, and have the spring/shackle ID's if needed. They are different than a non Crew cab.
__________________
Chris
'67 Fairlane, '79 F-100 2wd shorty, (2)'79 F-150 4X4 shorty, '79 CrewCab 4X4 shorty, '79 E-250 4X4, '91 E-150 Party van, '94 Civic, '94 21' Eliminator Daytona (547cu BBF, 8-71, 1050hp), '97 F-350 PSD 4X4 CrewCab, 99 Ranger 4X4
Old 06-15-2015, 05:41 PM
77&79F250's Avatar
77&79F250 77&79F250 is offline
The parts guy...
77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of
Have you checked here, I believe the guy is a FTE member?
Leaf Springs and Suspension Parts by Auto and Truck Springs
Ford Replacement Parts, RB Leaf Spring Bushings
And or here? Old Ford Crew Cab Community | Old Ford Crew Cab Community, Pre 1980 Ford Crew Cab owners community and information source.
__________________
77&79 F250 Rich & Penny
77 351M auto, a/c, add a leaf 33x12.50's
78 (79 headlights) 460 4 spd, 4", a/c and 35's
79 351M 4spd 6" Skyjacker Edelbrock-Holley-Hedman 35's
99 Ranger 4x4, 98 Expedition 4x4, 73 Bronco Hillbilly-Bug
71 Bronco 302 35" Boggers 5.58 gears spool/locker
Old 06-15-2015, 06:08 PM
Crewcabber's Avatar
Crewcabber Crewcabber is offline
Crewcabber is starting off with a positive reputation.
All the rear springs should be the same unless for some reason you wound up with highboy springs. Those stopped being produced in 77. Measure the spring width and let us know what it is. Number dummy should be able to get you a part number then they will be easier to find.
__________________
1997 F-350 cclb 4X4 460 E4OD 4" LIFT 35X12.50X16 OBD1
1977 F-350 cclb 2nd 460 C6 Ranger XLT
1995 EXTRA CAB s/b 2wd 2.3
1971 Safari Fiberglass buggy
1969 Chevy C20 factory A/C long bed
1933 Chevy Pickup
Old 06-15-2015, 06:12 PM
77&79F250's Avatar
The parts guy...
78 should be 3" wide 73-77 HB are 2 1/4 wide.
mikeo0o0o0 is a great parts hound also.
__________________
Old 06-15-2015, 06:16 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Jeffafa has the day off....
Old 06-15-2015, 10:40 PM
Springs are 3" wide. Front of rear spring bushing hole ID is 1 1/2" with the bolt measuring 5/8" OD. Rear of rear spring ID is 1 1/4", with a bolt OD of 9/16". Rear upper shackle ID is 1 1/8" with the bolt ID of 9/16". These measurements are done with a measuring tape, I do not have calipers.
__________________
Chris
Old 06-16-2015, 02:40 PM
Those dimensions help out at all ?
__________________
Chris
Similar Threads
1978-1979 Crew Cab build thread 1KILLERZ 1973 - 1979 F-100 & Larger F-Series Trucks 149 06-25-2015 01:26 PM
Need help with suspension 1978fordmoneypit 1973 - 1979 F-100 & Larger F-Series Trucks 10 01-22-2015 12:58 PM
1978 F350 Crew Cab Pickup, Where To Buy Used BED ???? GQROD 1973 - 1979 F-100 & Larger F-Series Trucks 104 12-08-2009 03:47 PM
1978 Crew Cab 4x4 Has Finally Come Home!! fordtrucknut 1973 - 1979 F-100 & Larger F-Series Trucks 16 07-18-2009 01:18 AM
differences between 1977, 1978 and 1979 F250 crew cabs fordblue_ca 1973 - 1979 F-100 & Larger F-Series Trucks 4 10-13-2002 07:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
