Truck keeps shutting off when I hit a bump.
Any input would be greatly appreciated. My 6.0 powerstroke keeps shutting off when I hit a bump. It's like everything died and reset and i loose all memory to sterio and eveything. When I got to work and poped the hood I tapped on the battery cover by the pcm and it shut off again. Any ideas?
Ok so I went back out and started the truck up. And when I knocked on the drivers side battery cover by the pcm it shut off again. So I pulled the battery and pulled the pcm plugs and checked for bad wires. (None). So I pushed them back on and made sure they were fully seated. Reinstalled the battery. Noticed my sterio wire going to battery was loose and sparking alil so I tightened that up. Started the truck and knocked on same spot to see if it would shut off and it did not... I'm hoping that's all it was but we will see how it is on my drive home from work.
blue924.9
02-19-2013 03:08 PM
Scratcher
13
07-11-2011 07:15 PM
