6.0 every thing is good but no start...
Have a 6.0 a guy brought in. died for him at a stop sign. Put scanner on it, FICM was 35v so I replaced FICM. Volts now at 48. ICP is 900. Fuel pressure is 50psi. No codes. No fire at all just crank. Tried a CMP. Runs on ether. Head gaskets are bad, it builds up to 15psi while cranking in degas bottle. But is that enough to make it not start? Ran ok till it died on him.
maybe...
Injector o-ring (or other failures) can cause a no-start condition. One easy check for injector problems:
Pull the fuse cover under steering wheel with a flat blade screw driver turn the screws 1/4 of a turn. Pull fuses 20 FICM, 40 Fuel pump, and 103 PCM. You might need a fuse puller or needle nose pliers. Be sure there is fuel above the standpipe. If you want pull fuse 40 last and use the fuel pump momentarily to fill the fuel filter housing. Then have someone crank while you watch for bubbles. Do not crank on it for more than 10 seconds max. This is the easiest way to determine mechanical condition of injectors. What happens is combustion gas will come through the pintle seat and into the fuel gallery in the head and up into the filter.
