does e4OD really suck that much power from the engine?
I purchased a 95 f250 with 145k on it and a bad head gasket. I completly rebuilt the top end with 1.7rr, a valve job and long tube headers. Added a 2.5in dual side swept exhaust. I have no check engine light and only emission faults stored as these were previously removed. Holes in the heads are plugged and thermactor bumps removed and polished. Heads are stock e7. Took it for a drive and I'm disappointed. I have a similar truck with this same build except it has gt40 heads and a c6. It pulls "okay". I towed my 06 f250 diesel from Columbus to Cleveland and was pretty impressed, but this thing just seems like it doesn't have much grunt. I cannot stand the shifting of the e4od. Seems like it just slides into gear instead of "dropping" into gear if that makes sense. I had the trans rebuilt with stock parts 2000 miles ago. .. anything i can do to improve the soft shifts? If there is, i think it'll be better. Has 4.10 gears and is 4x4. Tempted to put in my zf-s42 and be done with it
Yeah autos are power-sucking pigs. Not only does the engine have to turn all the inner workings in there, it's also powering a hydraulic pump (trans pump) and spinning a big heavy torque converter as well.
To fix the sad excuse for a shift, you can install a shift kit. Encho has a nice writeup here: https://www.ford-trucks.com/forums/1...l#post13059337
And yes it does suck, I don't like my auto either. I've started collecting parts to swap to a manual cause not only does it suck down power but the damn thing is almost never in the gear I want, and shifting it manually is a waiting game:
Move shifter... wait ten minutes... transmission finally shifts... then torque converter locks and pulls the RPM down just as the engine was getting into it's sweet spot.
On another note, my new deep trans pan is in. Waiting on the b&m to get here, hopefully tomorrow. Ill be installing saturday. Hopefully this helps out a bit.
You might want to read Mark Kovalski's posts in this thread https://www.ford-trucks.com/forums/1...l#post15449385 before popping for a deep pan. When someone with 19 years experience as a Ford automatic trans engineer says deep pans are a bad idea I'll choose to listen.
Lol. Never measured the heat under the truck but I know it's #&#%$! HOT under just about any vehicle because in high school I had a beater car with holes in the floorboards and the draft that came in was way hotter than the Florida heat coming in thru the windows. Had to duct tape over them it was so bad! So yeah the finned pan not working out makes perfect sense.
Yeah mine feels that way. I think it is because I'm not used to driving a 4x4 w 31x10.50 tires but it slows down fast if I let off. It also speeds up fast going down a big hill w no gas too lol. Also it does kind of shift slow too from 3rd to 4th. I though it was slipping but no codes. 1st 2nd is real nice and firm
Darn... i already bought it. But the only reason being is it has a bung for a trans temp gauge , a drain plug and my pan was rotting out. But now that i think about it, i dont think that my exhaust is going to clear it. I plan on using a cooler with a fan on it and use a temp switch to trigger it. Whats a good temp to have it come on at? I dont have a guage on it yet, but my 6.0 towed at its hottest, 180*. BUT i know it has a massivr cooler on it.
