1950 ford f1 226 rebuild thread - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Log In
Old 06-14-2015, 04:40 PM
3twinridges's Avatar
3twinridges 3twinridges is offline
3twinridges is starting off with a positive reputation.
Folks, thanks to Doug of Montana, I have a spare 226 engine for my 1950 Ford F1 now. For the last month I have been tearing it down (Doug had torn most of it down already) and cleaning / labeling / oiling / bagging all of the parts. I have the block stripped except for the manifold studs and the oil filler tube. Has anyone taken the oil filler tube out of a 226? It will not budge even after heat. I see no bolt holding it.
Click the image to open in full size.
Old 06-14-2015, 06:37 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud of
Can you get a hammer on the back side? The tubes on V8's are sometimes really stuck in there, I'm not sure if they used a roller to swedge them in or what. 60 years of fumes don't help.
__________________
Ross
1952 F-1 Flat V8 3-on-the-tree MSD, Rochester 2G, Red's Headers
"Never attribute to malice that which is adequately explained by stupidity" -- Hanlon's Razor
Old 06-14-2015, 06:42 PM
Yeh I tried that from the inside too, gave it a few whacks and nothing, even after heat. I think it just stays, I can clean it the way it is.
Old 06-14-2015, 10:45 PM
Cougar54 Cougar54 is offline
Cougar54 is gaining momentum as a positive member of FTE.
I got mine out of both my 226 engines. They were stuck but I used a chain style strap wrench and wrapped the chain around the tube at the bottom near the block. By working the tubes back and forth they eventually loosened up and came out. The chain wrench left a few bite marks where it was grabbing the tube but the damage is not noticeable.
__________________
Doug
1950 F1 226 (in pieces)
1949 F1 283 (Cheby)
1950 F2 226 (being restored)
Old 06-30-2015, 11:09 AM
Folks, still continuing to clean this old 226 and prepare for rebuild. To date I have cleaned all bolts, cleaned all engine parts, and everything is now stored in oil.
I have mic'd the journals and there appears to be very little wear so I am going with standard bearings and rings. I was able to find a set of NOS Ford cam bearings, rod bearings, crank bearings, and piston rings. I am about to degrease the block and get it ready for re-assembly and paint.
One challenge I am having is that 1 engine mount studs is broken off in the block, about 1/8 below block surface. I think it is too low to try the welded nut trick so I have been pondering how I am going to get it out.
My first thought is to use a small drill in combo with a dremel cutting tool, and form a small horizontal slit in the stud base all the way through, then use a big flathead screwdriver with heat and try that. If that fails, drill it bigger with left handed bit and try an easy out. Any other ideas? There can't be more than 3-4 threads actually left and there is room in the stud hole on both sides to hold penetrant to allow for adequate soak.
Old 06-30-2015, 12:26 PM
ALBUQ F-1's Avatar
postin' fool
I take it the stud isn't in a thru-hole? i.e., accessible from both ends? EZOuts have never worked for me. If you can get a pilot hole drilled absolutely dead-center on the remains, I'd be inclined to buy some numbered drills and just drill it til you can pick the threads out. Even if you had to helicoil it that wouldn't be the end of the world on that, you should have plenty of meat there. What size is the stud, 3/8"?
Have you miked the bores? It's unusual to find a cylinder not worn at least 20 thou on these.
__________________
Ross
Old 06-30-2015, 01:34 PM
Ross - on the stud, yes it is in a thru-hole, does that change my chances?
On the bores, no I did not mic them, I guess I jumped the gun a little on the NOS purchase! I figured since the crank and rod journals would be in tolerance with standard size so would the rings.
Did I also mention that this is my first rebuild and I have no idea what I am doing!
I am sure that will be apparent as this thread unfolds, be patient with me!
Jonathan
Old 06-30-2015, 01:56 PM
ALBUQ F-1's Avatar
postin' fool
How far down-hole is the back side of the stud? Is it closer to the inside surface to do the welding trick? Many times just laying some weld on the end will break them loose. If you can drill from the back side, you don't need LH bits.
__________________
Ross
Old 06-30-2015, 02:41 PM
its farther in on the backside than on the front. On the weld trick, what I am afraid of is actually welding the stud into the block given that the nut will not sit flush. 1) do you think putting a washer in the hole to help the weld form into the nut will help? 2) do you think the welded nut trick is even possible with a HF welder?
I kinda go back to a good centered drill hole and then pick the threads but that is the point of no return there......with helicoil right behind it. I have already had to helicoil one stud on the manifold flange and it just never feels right.
Old 06-30-2015, 03:00 PM
ALBUQ F-1's Avatar
postin' fool
I'd drill it. You could be done in the time we've spent talking about it! Nothing wrong with helicoil on a bolt in this kind of service, if it comes down to that.
__________________
Ross
Old 06-30-2015, 05:39 PM
If you plan to have the block hot tanked, the heat and solution will remove any rust or contaminants that may have locked the bolt in place. Drilling a pilot hole and extracting it may be a very easy job after that.
__________________
Doug
1949 F1 283 (Cheby)
Old 07-12-2015, 04:56 PM
I soaked it in penetrant first. Then I used left handed drill bits and it just popped out. Didn't even have to break out the welder!
Old 07-12-2015, 08:53 PM
ALBUQ F-1's Avatar
postin' fool
It's downhill from here! (hopefully)
__________________
Ross
Old 07-12-2015, 09:02 PM
Skalywag Skalywag is offline
Skalywag is gaining momentum as a positive member of FTE.
I'm looking for an air cleaner and heat shield for a 50 226 if any of you guys have a spare let me know.
__________________
1950 Ford F1/ Jezebel
(The Other Woman)
Old 07-12-2015, 09:14 PM
Heat shields are tough and bring big money on eBay. Air cleaners are easier to find, I think there is one out there now on eBay. If I had a spare I would work with you on it but I dont.
jb
Similar Threads
1950 f1 parts 3twinridges WTB - Parts & other 1 01-28-2015 08:18 AM
1950 Ford F1 226 cylinder head 3twinridges 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 01-21-2015 01:27 PM
1950 Ford F1 226 intake and exhaust manifold 3twinridges 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 01-07-2015 11:17 AM
226 Road Draft Tube for 1950 Ford F1 3twinridges 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 11-30-2014 10:06 PM
226 Road Draft Tube Cougar54 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 05-12-2014 10:14 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
