1950 ford f1 226 rebuild thread
I plan on getting back to this build next weekend. I have been a little side tracked since Doug of Montana dropped this off in May. Two family vacations and a Tom Cruise film called Mena that is filming here in Ball Ground Georgia has kept me busy. My wife, my sister, my brother in law, and myself were all background actors. Today was the last day of filming and I scored this pic! Big Tom Cruise fan all my life so here you go.....I know this is OT but I think because I had on my F1 shirt it qualifies as relevant and should be published!
jb
jb
OK, here is another part I am unaware of. Heat shield. Where does it go and what is it shielding the heat from? I looked at the parts book pictures but found no heat shield in the carburetor/air cleaner area for a 226 in a F1 or F2.
Could be, that would make sense also. I've always looked at the way the engine is designed, with the fuel and fuel line that close to the exhaust as dangerous. But I guess you could say that about anywhere you put it. I know my shield is in good shape and is around to stay regardless of its mission!
Jb
Jb
Still working on the spare engine, getting it ready to put back together. Focus this weekend was breaking down the Holley 847 carb, cleaning everything, and getting ready for the carb rebuild and hardware kit from Mikes carbs. He also has a good video out there for the 847 for my 226 friends. I also picked up a nos fuel pump, any good tips on getting a good quality modern fuel diaphram for it?
Took the old truck down to the cruise in this weekend to show off my new tires! I follow all the threads you guys post on the steering boxes, but let me tell you taking those old dry rotted Remington's off and putting new rubber on corrected all of my problems. I am not going to touch a thing now on my box.
#29
This weekend I worked on rebuilding the carb. I finished last night along with my modified air filter (old school bath look but modern paper filter inside). I was reading my manual today and noticed my top air horn doesn't have the same screw placement as the 7ht9510. It matches the one exactly in my truck now and all of the parts in the 847 kit were identical. So is it an 847 or something else? Notice the screw hole in the gasket not used.
#30
