to do or not to do
Two things of note:
1. 16.5" rims and tires are harder to find these days compared to 16" rims. One cheap source for 16.5" tires is military(humvee) tires; If you're looking at someday putting large tires on your truck, you can get those cheaply. Also, I've seen superswampers in 16.5" size.
2. If you need, your truck will get down the road with 1 oddball tire(large or small). It'll feel weird though, and I'd not do it for *too* long. This means that you can use one tire from set A as a spare for set B, as long as set A fits.
3. At some point, if you need a spare 16" rim so you have a set of 5 of those as well, look around junkyards. But be aware that there are 8-lug Dodge and Chevy rims which "almost" fit: the hole pattern is the same, but the inner rim is just a hair too small to fit our trucks. Just watch for that, and you can probably pick up things extremely cheap(a rim is a rim, if it'll fit).
First, do you even have a LS rearend to worry about? If not, it doesn't matter at all. And if it happens on the front... it doesn't matter.
It may drive a little funky if you've got an odd size tire(like, inches different), but like you said, it's an emergency spare.
I drove like 15 miles with 3X LT235-85-R16's and 1 36.5X12.5X16.5 humvee bias-ply tire(It was on the right rear). I went highway speeds for some of it, though it felt a little odd with the right rear corner being so high. Mind, I don't have a LS rearend. And it was only 15 miles.
foxbody429
12-25-2012 08:31 AM
hittman1422
64
07-21-2009 09:40 PM
dpbrowne
03-13-2005 09:42 AM
