Weak a/c
Weak a/c
My 92 f150 4.9 suddenly has very weak air conditioning. It just doesnt get very cold unless im doing 70 down the highway. And even then it still isnt as good as it usually is. Low side pressure is good (55 psi and its about 90* outside) condenser and evaporator are very clean. No blocks in the return and the evap is making water. I believe the orifice filter/tube is clogged. Where is the orifice located on this truck? Do i need a special tool to remove it? Thanks
Does the compressor cycle on and off a lot? To get to the orifice tube you have to evacuate the system and disconnect the liquid line from the firewall to condensor on passenger side.
Although if your compressor is grinding it would probably be a good idea to replace it and flush/replace your hoses to clean out any debris in your sytem
no its not overcycling. I have all the equipment to flush/evacuate the system properly, I service residential and commercial a/c's for a living. I just need the adapter so I can hook up my gauges to the truck. the cars are definitely different than homes and buildings
I had that thought but it was so damn hot out I said ***** it and took a chance. I drove the truck 240 miles straight with the air on and it didn't make the noise again and its actually still cooling. the truck is home now so I can leave it until Im ready to correct the problem. thanks for the concern!
SapperJoe
1997-2006 Expedition & Navigator
06-22-2017 03:04 AM
ForTiLLiaN
03-08-2007 03:10 PM
