Second starter failure in six months
Hey guys, I have a 75 e150 with a 300 and a 3 speed. This is the second time that I have had problems with the bendix that engages the starter gear. The motor spins, it just won't connect to the flywheel. I bought my last starter from Napa, which usually has decent parts. Any recommendations on where to get a good starter?
Did you make sure they gave you the correct starter? The manual transmission takes a different starter then the automatics. And since most Econolines were automatics they may have given you the wrong part. Just something to check & confirm.
The second thing is did you inspect the flywheel ring gear to make sure it's not missing some teeth?
The following users liked this post:
I replaced the ring gear. The delay in the dying bendix had the starter spinning when it made contact, grinding chunks out of the teeth. The last starter has already started doing the same thing. The starter has a lifetime warranty and the new one works great. It's like the bendix dies a slow death.
frankenford 66
09-08-2013 12:24 PM
mmuenchow
03-29-2010 04:48 PM
78250crewcab4x4
01-22-2010 10:28 AM
gingerbreadmaniac
08-26-2005 05:14 PM
