Technical help needed - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Modular V8 (4.6L, 5.4L)
Log In
Old 06-14-2015, 12:01 PM
Rider48 Rider48 is offline
Rider48 is starting off with a positive reputation.
I am new to the forum but after struggling for over a week (evenings and weekends) to fix my truck, I need a little help from others.
Long story short, 1998 F150XL 4.6 auto 2wd, non-PATS, non-COP (125,000 miles), died suddenly while driving without prior symptoms. Threw codes for failed coil pack A and D. Metered coils as per manual and proved within spec. Swapped in new coils to see, no difference. Trying to start it seemed more a fuel issue, sometimes starting with terrible idle, and never running longer than a few seconds. Not understanding how 1/2 of each coil pack could fail simultaneously, I tested fuel system as precaution, good pressure that holds, filter changed. Went back to chasing ignition/electrical. All fuses good. Power at both coil packs as it should be on center pin. Here is where it finally makes some sense; testing reference signal for coil packs while cranking with LED test light. Unplugged pass-side to test: A-good, B-good, then when unplugged other coil to test while cranking, truck started and idled (rough) while testing C which was ok. Testing D shows no reference signal, in fact short to ground. Disconnected harness at PCM to prove reference wire, no shorts or ground, indicating trouble in PCM. Removed reference wire for coil D from harness plug at coil at connected. Truck starts, runs, drives, even idles with a slight lope on 6 cylinders. The only code it throws is for failed coil D. In my opinion I have proved PCM as problem. Ford does not sell replacements but lists it as reprogrammable
My questions are as follows.
1. Would flashing existing PCM solve this or is replacement required?
2. When sourcing wrecker part, would PCM from truck with same options plug-and-play or require flash?
3. If not from truck with same options, and requiring flash, what PCM will work? I have read that the donor part must come from vehicle with same trans, and elsewhere that 5.4 and 4.6 are interchangeable to some degree. If flashing, how much of this is true? More specifically, I have a parts truck with 4.2 V6, same auto trans, but it's '99 so it also has PATS. Would this PCM be able to be flashed and work for me? Or am I relegated to finding pre-PATS, 4.6, auto PCM only?
4. Is Ford able to flash PCM on bench, not in/with truck? Truck is some 40 miles from dealer. Installing new PCM would cripple it, requiring a tow, or I would have to drive it on 6 as is, and install new PCM in parking lot before flash; the alternative, paying them to install.
Has anyone experienced this?
Old 06-18-2015, 04:49 PM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
You would need the same type PCM you have, a v6 wont work neither will a 5.4 PCM. All 5.4s were equipped with COP ignition and the v6 only has 3 ignition drivers and 6 injector drivers. You shouldn't have to flash a used PCM but you may have to flash a reman. The only issue will be the VIN in the PCM won't match the VIN on the truck but that wont keep it from running.
Ford senior master tech
Every 5.4 3V owner should have Lisle tool #65600
8L3Z-6M280-B updated VCT solenoids for 5.4 3V rattle
Old 06-19-2015, 10:26 PM
Thank you for your response. When looking for a donor vehicle, obviously I'll need a 4.6 auto with same trans code "U", but what other options will matter? Would 4wd work for me? I know I need a '97 or '98 pre-PATS PCM, but what about power options like windows, doors, mirrors etc.? I believe those are GEM controlled aren't they? So they're irrelevant when it comes to PCM, correct?
Similar Threads
EEC-IV engine trouble code 226 1995 4.0 V6 No Start SOLVED grostig 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 1 11-04-2015 11:04 PM
98 f150 no spark at coils and no fuel being injected MADMECHANIC1991 1997 - 2003 F150 9 01-12-2015 06:39 PM
Some great sensor information fordpride 1999 - 2003 7.3L Power Stroke Diesel 14 09-07-2014 03:00 PM
Put truck back together, now engine code p0351 mfp4073 Ranger & B-Series 3 06-17-2014 03:38 PM
99 navigator Died while driving??? Robsride Expedition & Navigator 14 06-22-2010 05:12 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
