oil leaks on top of engine, 77 351 m
Old 06-14-2015, 07:44 AM
outahere's Avatar
outahere
outahere is offline
Trying to get all the leaks fixed, need some advice. I've changed oil pan gasket, timing chain cover gaskets, valve cover gaskets and the distributor o ring, but when the truck gets "road hot" and I stop, getting leaks at the front and rear. I noticed that there is oil on the tunnel above the bell housing, so I changed the oil sending unit and oil still puddles behind the intake manifold and eventually runs down the bell housing. Same thing around the distributor, any advice? Losing a quart about every 600 miles. It only seems to happen after driving for a while.
Old 06-14-2015, 08:17 AM
jconis's Avatar
jconis
jconis is offline
Sounds like the rubber seals front and rear of the valley pan are next on your list.
Jeff
Old 06-14-2015, 08:22 AM
outahere's Avatar
outahere
outahere is offline
thanks, Jeff
Tough to change?
Old 06-14-2015, 08:29 AM
jconis's Avatar
jconis
jconis is offline
The valley pan is actually the intake manifold gasket, so its not hard to do, but if its the factory manifold, that bugger is heavy. Also ditch the rubbers that come with the new pan and just use blk rtv ...
Jeff
Old 06-14-2015, 09:48 AM
77&79F250's Avatar
77&79F250
77&79F250 is online now
Moderator & parts seller
Received 3,277 Likes on 2,435 Posts
X2 on sounds like your intake manifold "S" gaskets are leaking.
Get it to TDC and pull the distributor, made sure the oil pump piece stay in the pump (probably will) or comes out with the dizzy.
And yes that steel intake intake manifold is HEAVY, like 80 lbs. Use 2 people and a long piece of pipe ran thru a chain bolted to where the carb sets. Like if you had a "carb plate".
After cleaning the S gaskets areas VERY WELL, use a bit of light weight sand paper to roughen up the mating surfaces on the front and rear of the intake and block (where the S gaskets were) and then use high temp RTV like the Permatex gold brand.
Tighten and torque the intake manifold bolt in a criss-cross pattern to the required specs.
Come dizzy install time use a dab of grease applied with a screwdriver to make the oil pump shaft stand up straight, and hopefully the dizzy will go right back in.
Old 06-14-2015, 10:58 AM
outahere's Avatar
outahere
outahere is offline
thanks for the advice, I'll
Be using it Saturday!
AK Jim
Aerostar
09-12-2014 09:25 AM
Argess
10-22-2010 02:07 PM
400Nut
06-11-2006 01:22 PM
moon42
10-31-2003 12:07 AM
tranthac1
05-23-2002 08:13 PM
Quick Reply: oil leaks on top of engine, 77 351 m
