Rear drop question?
Rear drop question?
I put SIDS 2" drop axle on the front of my stock 52 F1, with Posies 3" drop. Looks great!!! The backi put the 3" drop springs and it's just not low enough. If I remove every other sprin how much drop can I get? Looking for about 2" more. I know I could do a rear axle swap but I'm scared it's too low and will let axle pumpkin hit the bed. I would like to install the wood stock bed? Got some pics and ideas guys?? I'll send a pic later
I installed posies on my black '51 and it actually raised the rear end. I ended up taking out some leaves (leafs?). Here's what I posted on it back when i had this similar problem. Good luck!
https://www.ford-trucks.com/forums/1...-thoughts.html
Wally
Wally
Here are some before and after pictures that will give you some idea of how things settled out.
After settling
Before settling but larger tires in the rear
Yes, a lot of people lower their truck by removing every other leaf from the stock spring stack. The Posies springs are already built to be as low as possible, DO NOT remove leafs from the Posies springs! Did you load the suspension by putting the truck's weight on it before tightening the shackle pin bolts? Did you use lowering (shorter) non- nitrogen filled shocks? Have you driven it at least 500 miles to settle? I'd check the Classic Haulers catalog for other things you can do to lower the rear such as lowering shackles and/or moving the spring mounts higher on the frame. You could also use lower profile tires. Flipping the axle (putting it on top the springs) will require major surgery/modifications.
Yeah we did that. Like I said I have 5" drop in front 3" in rear. 2 more in the back epwould be perfect. Axle flop is a big deal and would put pumpkin up into my bed. That sounds like a lot of work.....Soooooo what's out there to drop my F1 rear about 2"?????
Ext Y hangers?
Adj leaf mounts?? I was on Classic Haulers today, it gives no details about either product...
Ext Y hangers?
