Grinch is getting a new engine pan gasket, OBA, 38R. Step by step engine/trans removal W/ pics
Old 06-12-2015, 06:21 AM
scotttahoe's Avatar
scotttahoe
scotttahoe is offline
The Grinch that stole my wallet!
What's happening, For years the Grinch had a leaking oil pan gasket and losing a gallon of oil every 800 miles and was leaving embarrassing stains every where we went.
The plan,
Oil Pan Gasket
GTP38R
Billet Plenums
International Bellowed Up Pipes
AFe Intake Manifold
FRX
Boots and Clamps
Upgrade Gauges
Injector O-rings
CVD Fittings
Banjo Bolts
99.5 Turbo Pedestal
On Board Air (belt driven)
Drive Shaft U-joints
Probably will do,
Melling LPOP
Cylinder Oil Plugs
Welded Piston Jets
New AFe 6637 Air Filter
Up for other ideas
The trucks name "Grinch" is a done deal
Took the truck to a Dyno and did 3 pulls before repair and mods. As she sits pretty close to stock other than what you see in my sig.
HP-266
Torque-538
Some snap shot from AE.
In order from top left going right.
Fuel Injector Pulse Width
Injector Control Pressure Duty Cycle
EBP
MAP
Engine Oil Temp
RPM
ICP
Old 06-12-2015, 06:46 AM
scotttahoe's Avatar
scotttahoe
Compression Test
Did a compression test to make sure all this was worth it for this pig.
Here are the numbers at 6K feet elevation.
Cylinder 1- 380
3- 360
5- 360
7- 350
Cylinder 2- 350
4- 360
6- 350
8- 360
Remove air intake filter/pipe. Remove intercooler pipes. Unbolt valve covers. (didn't do a how to) plenty of write up on this part.
Probably not necessary but blow out oil around glow plug with air or soak up with rag. Remove wire to top of glow plug, I used needle nose pliers. A 10mm deep socket to remove glow plugs.
Screw in (hand tight only) compression tester.
Did crank test on all cylinders.
I tried to do a running test, but my compression tester was not having it. It broke
That is not the glow plug screwed in. Thankfully it was only hand tight!
Old 06-12-2015, 06:54 AM
scotttahoe's Avatar
scotttahoe
Motor Running With VC off
All injectors are AB. 220K miles and looks pretty clean
Left (driver) side.
Right (Passenger) side.
Old 06-12-2015, 07:14 AM
scotttahoe's Avatar
scotttahoe
My ride for the next month.
Old 06-12-2015, 01:18 PM
Jesser02EX's Avatar
Jesser02EX
Jesser02EX is offline
That looks awesome, I'm very interested in your belt driven air compressor!
Any details to share?
Old 06-12-2015, 04:39 PM
mjtpolice76's Avatar
mjtpolice76
mjtpolice76 is offline
Subscribing
Old 06-12-2015, 06:59 PM
jhl3's Avatar
jhl3
jhl3 is offline
Awesome! I look forward to seeing the updates with the progress that you make. Good luck!
Looking forward to the final dyno runs too.
Old 06-12-2015, 08:30 PM
OldBlackCat's Avatar
OldBlackCat
OldBlackCat is offline
Git- er -dun!
Old 06-12-2015, 10:08 PM
petrokiller's Avatar
petrokiller
petrokiller is offline
WooHoo! Gonna be a new truck. Grinch will be happy win he rides through town scaring everybody.
Just check the list off and keep going.
Love the temp driver. Hope windows roll up/down easy.
Old 06-13-2015, 01:06 AM
scotttahoe's Avatar
scotttahoe
I couldn't find anything on how to set this up so I just did a bunch of research and don't really know if it's going to work, it has to work. So far what I have is a 2nd alternator bracket and will be moving the original alternator down to the lower side of the motor. I'm using an A/C unit (can't remember the name off hand and will look at it later) it's out of a Dodge cummins and has the correct amount of ribs for the belt.
Edit: Sanden A/C compressor.
Thank you, me too. Hopefully we will see a decent jump in numbers!
It will be a new old truck. Lol. The temp truck is a 1953 GMC straight six. I restored the truck 2 years ago and drives beautiful. Left the patina, kinda like it. The windows have all new rubber, felt and track. They work nicely.
Old 06-13-2015, 02:27 AM
scotttahoe's Avatar
scotttahoe
Removing the transfer case.
I started with removing the front and rear driveshaft. Unbolted the 4 bolts from the driveshaft to the transfer case output shaft then used a pry bar to separate it.
Then I unbolted the 2 bolts holding the center support bracket. Then I placed the drive shaft on the ground and out of the way. I screwed the 4 bolts back onto to the drive shaft and the 2 bolts back up on the center support bracket so I wouldn't loose them.
Front drive shaft. Unbolted the U-joint bracket.
Next, drain oil out of transfer case. I carefully removed the electrical plug from the transfer case and then removed the manual 4X4 linkage off the transfer case. Sorry I didn't get a pic with linkage attached to transfer case side.
This pic shows the 4X4 linkage attached on the transmission side, but is identical on the trans case. I sprayed some liquid wrench on the rubber piece that is attached to the linkage and used a pry bar to separate with little force.
Transfer case side along with the electrical sensor that needs to be disconnected.
I guess I didn't get a shot of the transfer case mated to the transmission, but I think you get the idea.
I unbolted the 6 1/2" bolts from the transfer case. Here you can see how the bolts are lined up.
The wrench would be on the transmission side.
Old 06-13-2015, 05:57 AM
JOHN2001's Avatar
JOHN2001
JOHN2001 is offline
How many miles are on your truck? It looks to be in great shape. The 53 Chevy I'm jealous of!!!
Old 06-13-2015, 12:01 PM
scotttahoe's Avatar
scotttahoe
The truck has 213K miles on it. Other than that dang oil pan she is in pretty good shape. I think the compression numbers were ok.
The 53 is 100% original from the factory. Rebuilt the motor to except unleaded gas and converted over to 12 volts. Only thing missing is the radio.
Old 06-23-2015, 05:39 AM
scotttahoe's Avatar
scotttahoe
Removing the transmision.
Ok, so after a funeral, wedding, and my birthday lets get this back on track.
Went to go drain the oil out of the trans and my wrench just spun. Something, somewhere, somehow got stripped. Now I get to remove all the bolts with all the oil still in the pan.
Not to sure what to do about the pan, might be looking into getting a new deep dish pizza pan or something. Here is the pan removed and filter out. I will get a the size of the socket for the pan bolts when the sun come up.
A look at the magnet with some shaving clinging to it but no chunks so that's good. With the oil drained I went ahead and reinstalled the pan and bolts.
I went ahead and removed the starter. There are 2 bolts on the bottom and one at the top. I used a 17mm socket on the lower 2 and 17mm wrench on the top. There are 2 wires that need to be removed. The large power wire is a 15mm socket and the small power wire is a 8mm socket.
This picture pretty much sucks, I will get a better one. It shows the top of the starter with a deep socket on one of the electrical lugs.
Here is a better pic of the starter. Large nut is a 15mm and the smaller nut is an 8mm.
Old 06-23-2015, 06:50 AM
scotttahoe's Avatar
scotttahoe
Removed the 2 oil cooler lines. I couldn't hold the camera and 2 wrenches. You will need 1 wrench to hold the bolt (not sure what it's called) on the trans side and another wrench to loosen the fitting.
With front and rear lines removed I went onto carefully removing the 4 electrical connectors.
1 on top near the front driver side of the trans. 1 on top near the rear of the trans. 1 on the rear passenger side, and the gear selector part of the reverse lights.
Follow the wiring loom down and you can see the connector.
Ha, ^^ found that missing bolt for the transfer case!
Quick Reply: Grinch is getting a new engine pan gasket, OBA, 38R. Step by step engine/trans removal W/ pics
