Need help with 98 e150 with 4.2 its got the shakes
Just re-read your posts,
One question, have you checked the timing?
You should have the spout connector with this, and follow specs to the timing with the spout removed.
Had a similar problem with a re-man 5.8, and about 2 months after all the parts change out, it started running rough on acceleration, scratching head one day, and I hooked up the timing light, and checked the timing, and it was retarded really bad, re-set to specs, and it perked up and has been running fine since.
The_Mad_Scientist
1997 - 2003 F150
04-02-2019 10:21 PM
puma4125
16
07-20-2006 09:36 PM
areyou4real
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
04-29-2004 06:49 AM
Cheap Monster
1978 - 1996 Big Bronco
01-02-2003 10:53 PM
