1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
fender flares
Old 06-11-2015, 07:00 PM
hoss66's Avatar
hoss66
hoss66 is offline
fender flares
Just wanted to show off the new fender flares i put on the truck. Went with the lund rx314s flares and including getting them painted i still have less money in them then just a set of bushwacker flares.
Old 06-11-2015, 10:16 PM
auburngrad's Avatar
auburngrad
auburngrad is offline
Look good. How's the fit?
I love the look. Just wondered how snug they fit and if the paint under would get damaged.
Old 06-11-2015, 10:30 PM
RumpityRump's Avatar
RumpityRump
RumpityRump is offline
WOW! those look GREAT! do those really screw into the fenders? I'm not sure but I believe the big bushwhackers do.
Old 06-12-2015, 06:49 AM
Quad Racer's Avatar
Quad Racer
Quad Racer is online now
Looks great!
And no they usually do not screw into the fenders.the hardware is for looks. The fronts use the same hardware as the inner liners and the rears have clips.
Old 06-12-2015, 08:35 AM
hoss66's Avatar
hoss66
hoss66 is offline
The fit is great, nice and snug to the truck but i would still expect some minor paint damage over time just from the rubber seal rubbing. Quad is right factory screws on the front and clips on the rear.
Old 06-12-2015, 11:07 AM
DetailerDave's Avatar
DetailerDave
DetailerDave is offline
I like those. I have some similar without the external fastener look. They have the rubber strip at the body, and there is no paint damage from the rubber. They have been on my truck for over 10 years.
Old 06-13-2015, 03:11 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
Nice looking. If you don't mind how much did they set you back?
also did you do the work and have any photos. (Yep we love the photos).
Sean
Old 06-13-2015, 02:20 PM
eberlestock's Avatar
eberlestock
eberlestock is offline
I had a set of bushwhackers that eventually wore through the paint! It took nearly 300000km to do so and the truck was always rolling on swampers so lots of constact vibration against the paint. I just put some whackers on my 06 and I put 3 coats of wax on the area before I installed them. Those lunds look good and if they are cheaper, great
Old 06-13-2015, 03:29 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Why not use some 3M tape under then at the contact points?
That could keep it from rubbing even if it's a bit of a bitch to
remove the stuff. I hard a heat gun and monofilament line does the trick.
Sean
Old 06-13-2015, 05:54 PM
hoss66's Avatar
hoss66
hoss66 is offline
fender flares
the flares only cost $222 and the paint was another $177. I am on vacation now but when i get home i can take some pics of how they are installed
jbehuniak
06-23-2016 08:43 PM
clintusaf
31
03-31-2010 05:40 PM
n5926g
2004 - 2008 F150
23
09-27-2009 05:40 PM
Trey
11-30-2005 05:25 PM
Quick Reply: fender flares
