Redhead Steering Group Buy
#136
Nope, it's my Cruze!
Had it just over two years and 11 months now, and put just shy of 36k on it. Which means 36k less on the Excursion!
I do really like the Volt, but the Cruze has the turbo I've always wanted, albeit small (a 7.3 turbo could probably eat this one for breakfast), and I've been having a lot of fun with it!
If I had to replace it, I'd probably go with a Focus RS, but I'm really not in a hurry to replace it. It does exactly what I want and does it well.
#138
I asked RedHead what they wanted used and I was told any quality power steering fluid. I went with Redline Synthetic because I wanted synthetic. It took 2 quarts but I didn't try to keep it from running out of the removed hoses.
#139
#140
#141
I've decided to keep my OEM since is was close to perfect, I had it adjusted about a quarter turn before removal.
#142
#143
Just emailed them a quote request. Found my pump with tons of shaft play while changing the belt the other day. I think that will answer my belt squeal as well.
Any vids you guys know of on how to change, I think I'll do my own if price is right. Border fees and price of the dollar is gonna jack the price 25-40%. But the reviews are good.
This is redhead steering gear out of Auburn WA correct? Thanks guys.
#144
on
#146
#148
#149
I just got my Ex back from the shop. What a difference the redhead box makes! Or maybe my stock box was just that far gone, who knows? That's what 200k miles will do.
I had a squeak somewhere in the steering shaft at low speed or stopped, I though it was a bad bearing somewhere in the shaft. The squeak is gone now. And so is almost all of the play it had. Still a little tiny bit but it's barely noticeable. Also, parking is a breeze now, it just turns smooth all the way until it hits the stops. Before it would just jam up and I'd have to inch the ex forward or backward while turning the wheel to free it up. Overall, I'm very pleased. Still need to do a high speed bump test and see if the Ex jumps around. If it does then I'll add the Helwig rear sway bar.
Thanks again for setting this up Lambert01!
#150
DidieX, the rear sway bar (if yours has none) is THE best thing I've ever done to a vehicle... it takes away so much of the sway, and hunting around in the lane (especially if the lane is rutted or crowned very much). For the difference in safety and confidence, I think its almost a crime that Ford didn't make 'em mandatory!
Swmpbgy1, you oughta use some kind of threadlocker- having that box come off would ruin your day (and maybe someone elses...)
