Rezz Find...
Old 06-11-2015, 12:41 AM
Toes2's Avatar
Toes2
Toes2 is offline
Rezz Find...
So picked up this AZ rust free example of a Fridge, My first old school Ford... Runs great and drives decent but brakes are sketchy, I have searched alot threads and never got a clear answer on a front disk conversion, I found ECIs kit, But not sure on what master cylinder,booster ect to use... The truck has the 4spd manual, any guidance is appreciated...
Old 06-17-2015, 07:50 AM
g4606's Avatar
g4606
g4606 is offline
Speedy has a kit for 280.00. GM calipers and no backing plate. Get a 68 up dual master local and an adj. proportioning valve off ebay 30.00. speedy has a good king pin set also. good luck
Old 06-19-2015, 04:38 PM
Toes2's Avatar
Toes2
Toes2 is offline
Thanks for the info
i'm assuming the 68-up Master would be from another Ford?
Old 06-19-2015, 10:08 PM
g4606's Avatar
g4606
g4606 is offline
Yes. f 150 series,I believe the one I just did was a 68 to 70 manual brake,don't use the rod from the box.much too long.the original rod has an eccentric bolt on the end and it will adjust approx. .750 total. If you can't double flare now will be the time to learn.it's easy.The kit from speedway has good bearings,dust cap,pads are organic. Only problem you may have is having the correct master cyl. fittings on hand,the one I just did had two large ports same size,the box gives you one.get another. good luck
Old 06-23-2015, 11:43 AM
crystalhand's Avatar
crystalhand
crystalhand is offline
Nice looking truck. I am also looking to make the disc brake conversion on my 55 350 and having a hard time finding what I need. We both may be forced to scrounge parts
Old 06-23-2015, 12:32 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by g4606
Yes. f 150 series.
No F150's until 1975.
Disc brakes introduced in 1973 F100 2WD. 1973/79 F100 2WD: Manual disc brakes were standard equipment, power disc brakes were optional.
Old 07-02-2015, 10:40 AM
TX62f100's Avatar
TX62f100
TX62f100 is offline
That truck is purty! Any thoughts on a crown vic swap up front to get disks and better steering?
HillBillyBuddha
10-23-2017 08:50 PM
Tomget
09-25-2017 02:31 PM
Rust Wrangler
1947 and Older Ford Trucks
07-03-2017 04:24 AM
Tomget
01-02-2015 09:37 PM
joedellcarter
10-03-2007 07:04 AM
Quick Reply: Rezz Find...
