Ok got this truck recently,
1995 Ford F-350, 460, 4x4, auto, long bed, and it has 295/70r17 tires "33's?"
But I was wondering if it had a lift on it.
The block spacer in the back is a 4 1/4" block under the leaf springs.
Is that stock?
F-350's sat pretty high. Everyone asks me how much lift is on mine and they are shocked when I say just 6". Then I have to explain to them that a stock F-350 sits about as high as a 150 of the same year with a 4" lift.
I've seen some that sit lower than others, I believe the F350's with plow prep packages and off road packages are the highest from the factory.
