95 460 overheats on freeway
Old 07-04-2015, 07:06 AM
justin90gsx's Avatar
justin90gsx
justin90gsx is offline
I'm looking and I'm not 100% sure there is a back plate behind the waterpump?
I see 1 gasket at the waterpump and I can't tell if it's casting or a plate? I I can't tell if there is a second gasket after what kind of looks like a plate?
I did just replace the upper radiator hose, it had a very small leak at times.
Old 07-04-2015, 07:07 AM
justin90gsx
What would be a good high flow waterpump that don't break the bank?
Also souls I pick up a back plate from the dealer or a junk yard?
Old 07-08-2015, 06:54 PM
cbakker's Avatar
cbakker
cbakker is offline
Originally Posted by justin90gsx
What would be a good high flow waterpump that don't break the bank? Also souls I pick up a back plate from the dealer or a junk yard?
You shouldn't need a high flow pump. I picked up an All Pro brand pump for my 460 from my local auto value a couple years ago. It may have even been a rebuilt one, but it has held up well so far. I was looking at the backing plate off of my 87 460 which is the same, and it must have bent or warped a little bit and the water pump blades rubbed on it and I think that is why I put a junkyard replacement on it. It could probably be made to work, and its yours if you want it.
Sent from my iPad using IB AutoGroup
Old 07-09-2015, 10:33 PM
justin90gsx
Where are you located?
I was just going to get a new back plate from summit for $20.
The waterpump is only a year old but I think it's just a cheap replacement.
But the might have not put the back plate back on.
And if the back plate is installed, then I figured a high flow pump would do it, because if I'm driving and rpms are at 1500 and starts to get pretty hot then I just turn overdrive off, which bumps up to 2000rpm then the temp immediately drops down.
My hoses are not collapsing either.
justin90gsx
Has anyone had this same issue?????
Old 07-20-2015, 08:04 PM
justin90gsx
So I pressure tested the system, help 15psi.
But when it was at operating temp the upper radiator hose would collapse but have pressure under idle.
Also burped the system with a burpper, and the funnel would fill up then Darwin down and repeat that a bunch of times.
Then when I shut the truck off, it literally shot all my coolant out the funnel.
Help!!!
Old 07-21-2015, 03:37 PM
cbakker's Avatar
cbakker
cbakker is offline
Are your rad hoses, and heater hoses hooked up correctly? Is your Long oil cooler still in place? The short hoses by the oil cooler can pinch and limit flow. If this is not the issue, it is either a missing backing plate or a blocked passage somewhere. Anything coming from the weephole?
Old 07-21-2015, 10:33 PM
justin90gsx
hoses are hooked up properly, no kinks or bends.
I spent most of today flushing the the whole thing out with a garden hose, then I ran a radiator flush and drove it around the block.
Flushed it again but I have to pick up some more coolant and my ford radiator cap should be in tomorrow.
Old 07-21-2015, 10:57 PM
justin90gsx
Nothing leaking from the weep hole. and looks like the back plate is there.
And as for the cooler I think it's there?
Truck is all stock.
I got my radiator cap from ford and coolant so I should know if the flush worked in a little bit!
Old 07-22-2015, 08:15 PM
justin90gsx
Flush complete, filled with coolant and burped it with my burpper of the tool truck, and put the ford radiator cap on.
I drove it for a couple milesand did great! And gauge stayed right in the middle the whole time and the hottest it would get is to the M after getting on it, then fan would kick on for a min then drop back down! And it's working great!
But......... I think the flush cleaned out a crack in the radiator and its leaking.
So I need a radiator.
And if it don't even over heat with a crack then a radiator should solve all my problems. Even tho it's new but looks like a cheap replacement.
Old 07-23-2015, 09:54 AM
cbakker's Avatar
cbakker
cbakker is offline
Good to hear. Drop a new one in. Its hard to go wrong with a ford radiator, but you will spend more for it. Aftermarket ones are hit and miss as you found out. Be sure to use distilled water when you refill.
Old 07-26-2015, 10:43 AM
justin90gsx
so I stopped into the ford dealer, they no longer make the radiators for this truck and told me only aftermarket.
But I called 1800radiator and there is one close to me with a lifetime warranty for $159.
But I would really like an aluminium one.
  #28
Old 07-27-2015, 04:56 PM
cbakker's Avatar
cbakker
cbakker is offline
Sounds like a good deal to me. A 4 core is nice, but not really necessary. If it has a lifetime warranty, I would take an all plastic one if they made one. the plastic side tanks don't bother me at all even though they can crack easier.
  #29
Old 07-31-2015, 05:30 PM
justin90gsx
So I just ended up getting a radiator at Oriley auto, has a lifetime warranty so I put that in with new lower radiator hoses and some Lucas cooling system treatment to run cooler.
And.... Well..... It does good but on the way to work this morning, "first drive" once it got to operating temp it got to the L on normal and kind of stayed there till I gave it alittle gas.
But it would usually stay on the R and it would get to the M and the fan would kick on and would drop it to the O.
I'm hoping that there is just a tini bit of air still in the system.
When I installed the radiator I burped what I could and the filled the resivoir and inch or so over cold fill line, and 2 drive cycles later it was just under cold fill, so that tells me more air came out.
So I topped it off and I'm going to keep driving it.
  #30
Old 08-03-2015, 03:25 PM
justin90gsx
So after driving it to work and stuff and replacing the coolant temp sender for the gauge. It still gets real hot......
So I guess I might have bad head gaskets or a crack or bad water pump.
No oil in coolant or coolant in oil....
No smoking out the exhaust either.
I'm done with this truck......
Ready to just drop a new motor in...
Quick Reply: 95 460 overheats on freeway
