E4OD beef up vs. 5 Speed conversion
Hi All,
looking ahead to some planned upgrades to my truck. I'm curious about the cost of an E4OD rebuild and improvements vs. the cost of a 5 speed conversion. This will not be a DIY job. I'm a B- mechanic with 2 jobs. I need my truck up and running in reasonable time. This will be done by a shop. Anyone have an idea of costs ? I've considered a new truck but at $ 70 k, I'll rebuild mine and buy a new camper ( or vacation cabin).
I did a 6-speed swap in my super duty a few years ago. found a complete 6-speed, tcase, pedals, & slave cylinder on craigslist for $800. bought a stock clutch for $300ish, flywheel $150ish, and then some odds and ends like shifter boot, clutch dust shield, flexplate bolts etc. swapped the whole thing over in a day. There are write-ups on PSN that make it super easy. I never really finished it, IE removed column shifter and PRND21 indicator. i fabbed up a tunnel cover that worked nicely.
In all honestly, it is not all its cracked up to be. I drive my truck daily, and in traffic it sucked. I didn't like the shift from 1-2 with the extra detent while towing heavy leaving a stop. Also the 3-4 shift really took the truck out of the power band when towing heavy, so you would have to ring it out in 3rd to keep the R's up for 4th....among other little things, i just didn't think it was all that great. So after about a year and a half, i had the auto rebuilt and swapped back to the auto. MUCH BETTER!!!!! You cannot compare a stock tranny to a built one with a good converter!!!!! now it is point and shoot
my money is on building the auto and call it a day....
ok then,interesting stuff (and BTW thanks Sean, you wrote a lot so i did not want to quote you as well and run out of space). You guys tow big and prefer the auto? I've got no tranny issues at all. This has become a lost season for me already with my old camper. I'm looking to next year already and want a new camper and good tow rig. I had not taken my camper off Long Island since I got the '97 PSD. Our roads are flat and I'm not sure I trust my stock Motor/ tranny on the big roads. my old camper is close to 7800 lbs. I'm gonna look for a newer one, maybe an ultra light under 6000 lbs. What do you think?
Regards Vinny
Regards Vinny
Not a manual guy here either. I like my auto towing my load too. Nothing against a manual, I've got one in my ranger, just don't want one in my tow rig.
If you are only towing 8k ish, you don't need a lot more power than a stock truck. I say maybe put a chip in it with some gauges and a fresh auto and you would be fine. Heck if its in good shape it should tow that 8k pretty easily without a chip. Make sure all the normal wear and tear parts are in good shape. You are going to look at 2500-3k for a decent auto, not bulletproof by any means, but if you drive like a normal human and not beat on it it will last.
My personal opinion is that there is no comparison when towing with a manual. I'm not letting a computer decide when my truck should shift. Yes there is some loss of power between shifts, but with the right combo it comes back pretty quick. My conversion cost about 2700. It can definitely be done cheaper. We did e fuel at the same time so it was 3k total. I didn't know about dieselsite at the time, so there were no built auto options that I could fit in my budget. All that being said, I have a very stiff 500hp clutch and it is terrible in traffic. Pure awfulness. Normally I'd big rig it and let 1st do it's thing through traffic, but the idiots around me have to cut over and in and out. Blah blah blah. If I had to do it all over again, I may go with a John woods or BTS. However, if I ever get my DD fixed, I may feel differently as I won't be driving the truck every day.
I'd think an auto would be quite a bit more fun to drive if the truck was a toy or hot rod, but thats not what my DD is. It tows heavy and quite often, and especially in the mountain passes gear selection is vital to uphill and even more importantly down hill.
