Will 305/70R16 fit 91 f250?
My own experience: I have 285/75/16s on my truck. Now, it is an F350, with solid front axle, and leaf springs. So, it may not have as much clearance as an F250. Don't know. Anyhoo, I did experience the occasional rub against the front springs, at full steering lock, going through a dip or some such. I installed 1/2" thick spacers (fortunately, had enough wheel stud length to do it) and haven't had an issue since.
JM2CW
Oh and by the way, lindstromjd, a 305/70 is within a whisker of the same size as a 285/75. Just sayin'
JM2CW
Um... the 305/70's are 20mm wider than a 285/75. Same height at 213mm, but different width.
Last edited by lindstromjd; 06-09-2015 at 03:41 PM. Reason: Had height and width backwards
I don't wish to argue but this is what I have learned.
305 (or 285) is the width of the tire in mm. 70 (or 75) is the aspect ratio. So:
305 X .70 = 213.5 mm. that is the measurement from the bead to the ground, not factoring tire squish
285 x .75 = 213.75 mm. So basically the same overall height. The width is what's different.
I stand to be corrected.
I went back and fixed what I said for the sake of anyone searching.
In a LT285/75R16...
*The 285 is the section width in MM.
*The 75 is the aspect ratio. To clear up any confusion...This refers to the sidewall height, not the overall diameter. In this case, 75% of the 285mm width is the height of the sidewall from the lip/bead of the rim up.
*R means it's a radial tire.
*16 in the rim diameter in inches.
Depending on brand and tread design, they both sit in that 33-33.5" overall diameter range. Often you can get away with either taller or wider in stock form. Going tall AND wide can get you into trouble. Another size to consider is a LT255/85R16. It'll fit a factory wheel better and just may fit w/o too much complication.
If you want a common metric LT tire size. Go with the 285s...
Received 3,090 Likes
on
lasitter
05-14-2011 11:57 AM
Loud4.9
03-25-2010 06:50 PM
RobPStroker
11-30-2005 03:51 PM
kohlerjd110
04-28-2003 09:29 PM
