cruising RPMS changing in OD
ok, so now that it runs correctly, i have a small trans issue.
truck specs: 1993 5.0 bronco. E4OD. 200k miles, 4x4.
prior to this issue, i would start the truck, head down the road, and get on the freeway about 6 miles away. after getting on the free way i would cruise to 70, and RPMs would be around 2300. a short time after i set cruise (2-3 miles), the RPMs would drop to around 2000. i have always assumed that the trans had gotten up to temperature, and the torque converter had switched to full lock. this was supported by the fact that in winter months, this RPM drop occured later in my commute.
the issue now, is that it doesn't stay locked. it still drops RPMs at cruise speed, but sometimes it goes back to 2300. its very random, and unrepeatable. might go three days without doing it, might do it 30 times on the way to work.
i have pulled codes related to this issue, and consistently gotten a code for the coast solenoid. is this code as simple as dropping the pan and replacing the solenoid pack?
what i know about automatic transmissions could fit in a shot glass, with room left over for some johnny walker black, so be kind.
thanks in advance!
-J0N
thanks in advance!
-J0N
Some info to test the impedance of the solenoid pack: https://www.ford-trucks.com/forums/1...s-2wd-4wd.html
A wiring issue could do it, too. A broken wire that makes intermittent contact, or a piece of insulation that wore through so that a wire intermittently shorts to something else, or a failing lockup solenoid, or remotely possible is a bad torque converter.
And the coast solenoid has NOTHING to do with the lockup. Fixing this will not correct your lockup problem.
A blocked orifice won't set a solenoid code. It is more likely that you have a broken wire than a failed solenoid, though either one is possible.
Frank250Tank
07-01-2016 07:12 AM
msmenne17
04-13-2012 02:23 PM
4AVIEW
04-09-2006 08:00 AM
