Horse power numbers
Thanks for all the info guys. I'm actually working on a set of headers and a custom Y pipe.
And no its not mass air. I'm guessing its an early '96 because its OBD1 also.
So from what im reading, all I need to do is slap on some 1.7 rockers and it will breath better...... Is there any extra pro-cations I need to take doing that? (ie; piston to valve contact)
You'll need a torx bit to fit the center upper to lower intake bolt in the middle of the upper. Also helps to have a couple of old long carb studs to screw into the lower at the front and rear to keep the gasket in place as you drop the upper back on. Also inspect the rocker ends of the pushrods for wear before reusing them. The pushrods in the roller cammed motors don't rotate in service like a flat tappet engine pushrod does, so after a time the rocker ends wear to a somewhat wedge shape. No worries about piston to valve clearance here. You're adding .030 lift at the valve. The two different EFI systems was divided at 7500lbs GVW if I recall, it wasn't an early/late thing. Also keep some antisieze handy to apply to the EGR tube threads when reassembling it. Don't hurt to put that on all the bolts that go into or through aluminum.
You guys are a great help, I don't usually get anywhere with forums
Horse power numbers
I made a set of these but they're old small block (long) head bolts, they sure make aligning the engine to a bellhousing much easier when working in the vehicle doing this.
on
No, Ford got an exemption for heavy duty trucks over 8500lb GVWR as they had the new Superduty with Triton engines in final planing stages for release in model year 1998. So there are many '96 and '97 old body style HD trucks(F250 and bigger) out there with neither mass air or OBD2.
Obsray96
08-16-2018 05:58 PM
littlehorse
05-28-2018 06:31 AM
Quigles4
11-19-2012 09:06 AM
1986F150six
07-30-2010 06:30 PM
