My air conditioning sucks
I figured Id find palm leaves of something in the blower or evaporator.. But nothing is ever that easy.. It doesnt blow very hard but it is cold. And does blow cold air, just not enough.
I evacuated then topped off the system to 200 and around 35 psi. But even after hanging a sheet behind the seats, the cooling is minimal. It does work, but I need more.
What else can I check? Iv read air dampers could be restricting air flow, but haven't looked close yet. This is a repowered van.
Anyone?
Thanks
Anyone?
Thanks
Does the fan operate properly? Not sure if that's what you mean, or you're saying that it still isn't blowing cold air. Get a small ac duct temp gauge and tell us what the temp is coming out of the air ducts with the fan on high.
You could check the ducts for leaks too, might help since these vans are so old now, or at least mine anyways lol
Sadly you share no real usable or helpful symptoms past "A/C sucks......"
Is the fan motor itself running at the different speeds?
Are the vacuum servos working properly?
Does the Max A/C function work?
Until you know for certain the air flow paths are working as designed its tough to read someone's mind.
Iv been told to increase my low side close to 40 psi , from 35 as I might not be flooding the evap completely. I also found a gap between the evap and plenum where the air leaked by and filled that with weather striping, further reducing air flow.
Low fan barely pushed any air before I started cleaning, and high still lacked the airflow I'm used to feeling on a good working system. The fan doesn't run with the ignition on. Seems the engine has to run but it was to late to test that.
The only servo I can see is the recirculation damper. But I haven't watched it during operation.
How many servo's are there? And do I have to remove the dash board to test them?
Only suggestion I might have is to check to see how much dirt has accumulated between the cooling fins of both the evap and the condenser. If you're careful and have a 'lower pressure' high-pressure washer, could clean out both to be sure that you have maximum airflow through both. The only other way to clean it out would be to use some pipe-cleaners and plain dish soap or mild engine degreaser.
This brings back memories of hats and gloves in my old dodge van.
I feel like , even if my front AC was working like a top.. It still wouldn't cool the cabin down where your cold and need to turn the AC warmer..
Whats the best option for additional AC, not considering a roof top?
Not positive, but yes cooler running down the highway
No rear air, and yes the rear windows do open. The weatherstrip around the rear doors have seen better days to.
http://www.carbonitecummins.com/Docu...%20Upgrade.pdf
I like the first sentence..
He dropped discharge air temperature 10 degrees bypassing the heater core.
Mean while, I removed the accumulator/drier and orifice tube which was installed in the correct direction. I don't smell or see the ford black death, but I do see a few metal flakes on the orifice tube screen along with the black deposits which might explain my 39/260 psi condition.
Should I simply flush everything except the compressor? Or do those flakes mean my compressor is about ready to fail?
Thanks
Now Im reading the flush solution doesn't evaporate under vacuum.. I'm glad I only flushed the condenser.
I'm finally earning that auto AC license Iv held for years never having really serviced one correctly by charging by lowside pressure. Bad practice.
Automotive AC Information Forum - ACKITS.COM
read what iceman says
