A/C switching to defroster?
Hey Folks!
The wife and I went out for lunch yesterday and I ran into some odd stuff with my A/C on the way home.
<O</O
<O</O
I had the A/C set and to blow out from the front dash, after a couple moments I noticed the noise level of the A/C blowing change and there was no longer any air coming from the front of the dash but rather from the top as if I turned on the defroster for the windshield.
I tried multiple settings both with and without the rear climate control running, same problem. It would intermittently switch to blowing from the defroster, and sometimes it would switch back on its own.
WTH!?<O</O
P.S. - I'm leaving for CA later this week. If I can't figure out a quick and easy fix I'll have to take to shop when I get back.
<O</O
<O</O
WTH!?<O</O
Hey Folks!
<O</O
<O</O
WTH!?<O</O
<O</O
<O</O
WTH!?<O</O
2000 Excursion with the exact same problem. Time to start checking for vacuum leak.
just stumbled upon this web page which should help tremendously...
http://www.justanswer.com/ford/3ink5...elorating.html#
GREAT post Nut
WELCOME to the world of XXXs Please add your general lo-cal to your profile
defrost cure on excursion
Many thanks to everyone for the info on fixing the defrost problem.
My turbo 4wd ex started blowing ac from the defroster yesterday WTF?
so come here to the trusty forum and after I got the info started looking for the leak and the pump running all the time. Replaced the lines to the hubs which had rotted and leaking,still blowing from defroster. I didnt wanna screw around cause its 96 here in Texas. Bought a new vac pump and esof .
Then before I installed them I found a tiny vac line that went to a diaphram I guess on the heater box? It had snapped in two....used a heatshrink electrical butt lol...worked.....so anyhow replaced the pump and esof and BOOM the AC is working from whatever vent I want!! It was prolly the lil vac line to that diaphram...but I now have 4 wheel drive and cool AC
THANKS to ALL Wash
THANKS to ALL Wash
