Turn Signals in 50 F1
#32
#33
If it's four wire, separate signal lights will need to be installed. Someone with the wiring diagrams will hopefully show up here.
#34
#35
This thread shows a wiring diagram for your use.
https://www.ford-trucks.com/forums/6...tat-900-a.html
#36
#39
#40
#41
#42
So here is my plan, to get the turn signal wiring harness from cg that has the flasher and fuse, and period correct cloth wiring. I talked to the guy that mAkes the bi-color led option up front, and he thinks he can make me a single led two stage intensity 6v. So that solves the front with led's and I am running led's in the back, so no incandescent. Can that work with the 6v signAl stat? Is there a 6v led positive ground flasher I can use to make it all work?
#44
#45
100550dvr
06-06-2019 12:04 PM
383lightning
12-11-2012 09:23 PM
panningbros
09-25-2010 11:42 AM
polarspeed
13
08-20-2010 03:59 PM
Bob at warsaw
03-24-2008 08:55 AM
