Are my expectations too high?
06-09-2015, 12:22 PM
Hopefully, that will take care of one problem.
Aaron is right about possible injector or hpop issues, but we just need look at one item at a time. On your next trip, take out the chip. You shouldn't need it on that light of a load. Then let us know how it behaves.
06-09-2015, 01:42 PM
295/40/24 tire is only 33.2 inches tall shouldn't make much difference on ratio.
that's 1.3" over the 235/85/16 31.9"
06-09-2015, 01:48 PM
Is your EBPV sticking? That could certainly put a lot of heat into the motor...
06-09-2015, 01:49 PM
That figures out to just over 4% loss of driving force. Not too terrible.
06-09-2015, 02:35 PM
on
Quote:
Originally Posted by
MisterCMK
Still learning the abbreviations... What is EBPV?
06-09-2015, 02:43 PM
Exhaust back pressure valve. It helps warm up by restricting the exhaust. I gutted mine same as many others have
06-09-2015, 02:50 PM
Exhaust Back Pressure Valve. Looks like a choke on a carburetor. Its just before the down pipe on the turbo.
06-09-2015, 02:53 PM
on
I dont think it would be sticking cuz it was putting out some smoke everytime it was struggling and when it downshifted
06-09-2015, 02:55 PM
If it restricts the exhaust your turbo can't spool properly resulting in black smoke
06-09-2015, 03:08 PM
on
MOOSE_MACHINE
Then that could definately be the problem
06-09-2015, 03:14 PM
It's a cheap check. Disconnect it and wire it open
If your temps are still high then it's not the problem
06-09-2015, 05:18 PM
lpzd
cowmilker08
It's not the tire height it's the weight of the wheels that are robbing power and putting extra strain
06-09-2015, 08:01 PM
fordpride
Those adapters are very heavy too.
06-09-2015, 11:28 PM
But once there rolling you should have the momentum already I would think. Idk. To much physics here
06-10-2015, 11:05 AM
MOOSE_MACHINE
You are right.
