Ditching Ball LInk Ends
Wife has an 04 Expedition and I'm tired of the junk moog sway bar links that only go a week then start clunking. I see from 11/04 and up has a regular straight link but still has a ball at the bottom. Has anyone used old style "bolt" link ends with 4 bushings like they used to? Is there anyway to get rid of the ball link ends permanently? Thanks.
Really taking a stab in the dark here, but the old ford pre-78 one ton 2wds used a short sway bar link in the front that was similar to what I think you are looking for. A bolt style maybe 8" long, uses 2 rubber isolator washers on the threaded vertical part, then the other end was an eye that held a shock absorber style rubber isolator and used a shoulered bolt to attach that to the chassis. So the attaching points are vertical and horizontal on the truck. I may be able to get dimensions as I know where my old 77 F350 resides.
There were essentially like this with a slight curve offset.
http://www.ebay.com/itm/New-Moog-Sway-Bar-Link-Rear-F150-Truck-F250-F350-Ford-F-150-F-250-F-350-K8662/121563633764?_trksid=p2054897.c100204.m3164&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140407115239%26meid%3D47e646e4486f450589ca7e260eb949e4%26pid%3D100204%26rk%3D11%26rkt%3D30%26sd%3D141682510446
rat49f6
02-26-2010 01:20 PM
vze2sgxa
1997-2006 Expedition & Navigator
12-18-2005 09:11 AM
Darth Baiter
08-24-2003 09:33 AM
