4wd light flashes 6 times
I have a '95 the 6 times every two minutes meant the 4wd system was unable to synchronize the speed of the two driveshafts. (it might also mean other errors)
does to '01 use a borg-warner 44-05 transfer case. If so one of your Hall sensors is probably nad.
when you shift into 4wd at a complete stop does the light only start flashing after you start driving?
pnp522
12-03-2013 10:55 AM
