390 Rocker Arm Rails
Hello everyone,
I have a 1976 F250 with a 390 engine. I just did a complete rebuild on it and bought a new, standard size cam and lifter set for it. I then found out that my rocker arm spacer springs are broken. Would anyone know where I can either find new springs, some spacers for them, or the whole assembly? Preferably on the more inexpensive side.
The part you're looking for is P/N B8A-6587-B Spring, valve rocker arm to shaft, locating.
Unfortunately the only dealer or obsolete supplier that shows any in stock is Bob Allen Ford in Overland Park, KS (913) 381-2999. They show 10 in stock, but from them, they probably won't be cheap. The only reason I'm listing Allen is because they are the one and only showing any in stock. Allen has a bad reputation when it comes to pricing on obsolete parts.
Edit: As an alternative you could find some tubing that will slide over the rocker shaft and cut to the correct length. There are high performance solid spacers available that are basically the same thing.
Sometimes my fingers are faster than my brain.
Tedster9
11-17-2017 07:09 PM
rdweathers
04-01-2011 07:08 AM
TG28
22
01-20-2007 10:01 PM
1975Ford
09-25-2006 08:44 AM
