Sealing up the C6
OK so putting the torque converter back in was tricky. I watched 4-5 youtube videos and the guy just puts it in, spins it til the first clunk, then the second and done. Tried that and it didn't work. I did notice that if I took the drain plug out I could wiggle whatever in the hell is in there. So I did that while trying to rotate it and clunk, then the 2nd and all was good. Spent an hour before that trying to figure out how to put that damn thing in there.
Back in and on the road. She sat over night and there's not a qt of oil on the ground. What a good feeling. That's been bugging me for months now.
I also put in a new flex plate. What a difference in starting. It spins much faster which tells me that the starter gear was bouncing all over the place. I'm sure that's why AZ starters weren't lasting long. Thanks everyone for your help.
You taking yours out to seal it up too?
It sucks. Having never done it I followed the steps in the manual. Took me about 8 hrs to remove/clean/put in seals and about 4 to put it back in. Tons and tons of inch thick oil/dirt build up on the entire undercarriage came falling onto me. I was wearing a pair of white shorts and a white t-shirt. After trans removal you couldn't tell I was wearing white clothes and I looked like a walking turd. I just removed my clothes in the alley, threw them in the trash, and went in and took a shower.
Enjoy yourself.
Enjoy yourself.
qman,
Thank you SO much for the inspiring words of success and excitement we will have. My boy and I are both redheads so you can imagine how this is going to go.
"What is said in the garage, stays in the garage". I hope mom doesnt walk out.
OH! you have a manual? hmm
The removal and install of trannies, this is not my first rodeo. The front seal is tho. I sure hope things don't jump out at me...
And yes Sir, Sealing her up so she stops leaking in MY work spot of the driveway.
There are 3 things you should replace:
C6AZ7A136A - paper gasket that sits behind the pump which sits behind the torque converter. Just pull out the pump and R/R. Hardest thing was to get the pump to let go. I put a vise grip on a rib on each side and hooked a slide hammer in there and pounded til it let go. This gasket doesn't sit in place. You have to make it stick and my Ford shop manual hint was to stick it with Vaseline. Works great.
C6AZ7A248B - o-ring that goes around the outer edge of the pump. This is what was definitely leaking on mine.
F2VY7A248A - pump shaft seal. Don't think mine was leaking but since I was there.
They're all cheap and I bought all 3 from rockauto.com
Nothing jumped out at me when I pulled the pump. That's what I was scared of. When you put your torque converter back in it should pop right in. There are youtube vids that show you how to do it and it's simple. Mine would not pop right in and if I had it to do over again I'd have bought a new one. I think they're like $60-70.
Good luck pal. It's one of the biggest chores I've ever done on any car.
That does the front. How 'bout the back? If you still have a Bump tranny with a Bump output shaft and a Bump driveshaft the trans output shaft seal was part number B3TZ7A011A. Which was replaced by a pinion seal (?!?!) part number TCAA4676A.
B3TZ7A011A:
<table width="100%" class="dataTable" id="dealerResultsTbl" aria-describedby="dealerResultsTbl_info" style="width: 100%;" border="0" cellspacing="0" cellpadding="5"><tbody class="hidden" id="dealerResultsBody" role="alert" aria-live="polite" aria-relevant="all" style="display: table-row-group;" jquery1720668796936408419="53"><tr class="odd rowStyle" _dt_rowindex="0"><td class="alignLeft">Griesel Motor Inc
(Okarche, OK)There's no returns on obsolete parts.
</td><td class="icon-column"></td><td>804</td><td>1</td><td class="alignLeft">7/15/2015</td><td class="alignLeft"></td><td class="alignLeft">(405) 263-7242</td><td class="blankCell"></td></tr><tr class="even rowStyle" _dt_rowindex="1"><td class="icon-column sorting_1"></td><td class="alignLeft">Parker Ford, Inc.
(Parker, SD)All parts cost + 10%. Visa, MC and Discover only. No COD or AmEx.
</td><td class="icon-column"></td><td>1,052</td><td>1</td><td class="alignLeft">7/14/2015</td><td class="alignLeft"></td><td class="alignLeft">(605) 297-4851</td><td class="blankCell"></td></tr><tr class="odd rowStyle" _dt_rowindex="2"><td class="icon-column sorting_1"></td><td class="alignLeft">Wolfe Ford
(Lidgerwood, ND)</td><td class="icon-column"></td><td>1,170</td><td>1</td><td class="alignLeft">7/14/2015</td><td class="alignLeft"></td><td class="alignLeft">(701) 538-7337</td><td class="blankCell"></td></tr><tr class="even rowStyle" _dt_rowindex="3"><td class="icon-column sorting_1"></td><td class="alignLeft">Soeby Motor Company
(Walhalla, ND)</td><td class="icon-column"></td><td>1,291</td><td>2</td><td class="alignLeft">7/14/2015</td><td class="alignLeft"></td><td class="alignLeft">(701) 549-3711</td><td class="blankCell"></td></tr><tr class="odd rowStyle" _dt_rowindex="4"><td class="icon-column sorting_1"></td><td class="alignLeft">Kerlin Motor Company, Inc.
(Silver Lake, IN)</td><td class="icon-column"></td><td>1,516</td><td>1</td><td class="alignLeft">7/15/2015</td><td class="alignLeft"></td><td class="alignLeft">(260) 352-2162</td><td class="blankCell"></td></tr><tr class="even rowStyle" _dt_rowindex="5"><td class="icon-column sorting_1"></td><td class="alignLeft">Cole Motor Sales, Inc.
(Ada, OH)</td><td class="icon-column"></td><td>1,618</td><td>1</td><td class="alignLeft">7/14/2015</td><td class="alignLeft"></td><td class="alignLeft">(419) 634-3831</td><td class="blankCell"></td></tr><tr class="odd rowStyle" _dt_rowindex="6"><td class="icon-column sorting_1"></td><td class="alignLeft">Owen Ford, Inc.
(Jarratt, VA)</td><td class="icon-column"></td><td>1,946</td><td>3</td><td class="alignLeft">7/15/2015</td><td class="alignLeft"></td><td class="alignLeft">(434) 535-8515</td><td class="blankCell"></td></tr></tbody></table>
TCAA4676A:
<table width="100%" class="dataTable" id="dealerResultsTbl" aria-describedby="dealerResultsTbl_info" style="width: 100%;" border="0" cellspacing="0" cellpadding="5"><tbody class="hidden" id="dealerResultsBody" role="alert" aria-live="polite" aria-relevant="all" style="display: table-row-group;" jquery17208485980922457772="55"><tr class="odd rowStyle" _dt_rowindex="0"><td class="icon-column sorting_1"></td><td class="alignLeft">Boeckman Ford, Inc.
(Kingfisher, OK)</td><td class="icon-column"></td><td>808</td><td>1</td><td class="alignLeft">7/15/2015</td><td class="alignLeft"></td><td class="alignLeft">(405) 375-4134</td><td class="blankCell"></td></tr><tr class="even rowStyle" _dt_rowindex="1"><td class="icon-column sorting_1"></td><td class="alignLeft">KOEHN MOTORS
(WELLINGTON, KS)</td><td class="icon-column"></td><td>856</td><td>1</td><td class="alignLeft">7/15/2015</td><td class="alignLeft"></td><td class="alignLeft">(620) 326-5915</td><td class="blankCell"></td></tr><tr class="odd rowStyle" _dt_rowindex="2"><td class="icon-column sorting_1"></td><td class="alignLeft">Cole Ford Sales Inc
(Hillsboro, TX)</td><td class="icon-column"></td><td>861</td><td>1</td><td class="alignLeft">6/28/2015</td><td class="alignLeft"></td><td class="alignLeft">(254) 582-5361</td><td class="blankCell"></td></tr><tr class="even rowStyle" _dt_rowindex="3"><td class="icon-column sorting_1"></td><td class="alignLeft">Bob Allen Ford
(Overland Park, KS)We ship on OPEN ACCOUNT to FORD Dealers! 913-381-2999. YOU CAN ALSO FAX YOUR ORDER TO 913-649-2067. WE BUY INVENTORY!!! Ask for details.
</td><td class="icon-column"></td><td>1,030</td><td>5</td><td class="alignLeft">6/16/2015</td><td class="alignLeft"></td><td class="alignLeft">(913) 381-2999</td><td class="blankCell"></td></tr><tr class="odd rowStyle" _dt_rowindex="4"><td class="icon-column sorting_1"></td><td class="alignLeft">Kinsel Lincoln Mercury
(Beaumont, TX)We ship OPEN ACCOUNT to all Ford L/M Dealers C + 10%. ALL DEALERS CALL (800) 816-2894 ... LYNDA'S WAITING FOR YOUR CALL!!
</td><td class="icon-column"></td><td>1,062</td><td>8</td><td class="alignLeft">7/1/2015</td><td class="alignLeft"></td><td class="alignLeft">(800) 816-2894</td><td class="blankCell"></td></tr><tr class="even rowStyle" _dt_rowindex="5"><td class="icon-column sorting_1"></td><td class="alignLeft">Barry Motor Co
(Danbury, IA)We do not monitor transacions. CALL IN ONLY!!!!! 712-883-2421. UPS pickup normally 2:00 P.M.
</td><td class="icon-column"></td><td>1,069</td><td>1</td><td class="alignLeft">7/15/2015</td><td class="alignLeft"></td><td class="alignLeft">(712) 883-2421</td><td class="blankCell"></td></tr><tr class="odd rowStyle" _dt_rowindex="6"><td class="icon-column sorting_1"></td><td class="alignLeft">Elmer Hare Ford Sales, Inc.
(Marshall, MO)</td><td class="icon-column"></td><td>1,108</td><td>2</td><td class="alignLeft">7/14/2015</td><td class="alignLeft"></td><td class="alignLeft">(660) 886-7462</td><td class="blankCell"></td></tr><tr class="even rowStyle" _dt_rowindex="7"><td class="icon-column sorting_1"></td><td class="alignLeft">Wolfe Ford
(Lidgerwood, ND)</td><td class="icon-column"></td><td>1,170</td><td>1</td><td class="alignLeft">7/14/2015</td><td class="alignLeft"></td><td class="alignLeft">(701) 538-7337</td><td class="blankCell"></td></tr><tr class="odd rowStyle" _dt_rowindex="8"><td class="icon-column sorting_1"></td><td class="alignLeft">Soeby Motor Company
(Walhalla, ND)</td><td class="icon-column"></td><td>1,291</td><td>1</td><td class="alignLeft">7/14/2015</td><td class="alignLeft"></td><td class="alignLeft">(701) 549-3711</td><td class="blankCell"></td></tr><tr class="even rowStyle" _dt_rowindex="9"><td class="icon-column sorting_1"></td><td class="alignLeft">Burnworth-Zollars, Inc.
(Ligonier, IN)</td><td class="icon-column"></td><td>1,537</td><td>2</td><td class="alignLeft">7/15/2015</td><td class="alignLeft"></td><td class="alignLeft">(260) 894-7176</td><td class="blankCell"></td></tr></tbody></table>
<table width="100%" class="dataTable" id="orderSummaryTbl" aria-describedby="orderSummaryTbl_info" style="width: 100%;" border="0" cellspacing="0" cellpadding="5"><tr class="headerStyle" role="row"><th tabindex="0" title="Selling dealership's location" class="alignLeft sorting_asc" role="columnheader" aria-controls="orderSummaryTbl" style="width: 479px;" aria-label="Location: activate to sort column descending" aria-sort="ascending" rowspan="1" colspan="1" jquery17208485980922457772="78"></th><th tabindex="0" title="Part Number" class="alignLeft sorting" role="columnheader" aria-controls="orderSummaryTbl" style="width: 101px;" aria-label="Part Number: activate to sort column ascending" rowspan="1" colspan="1" jquery17208485980922457772="79"></th><th tabindex="0" title="Description" class="alignLeft sorting" role="columnheader" aria-controls="orderSummaryTbl" style="width: 154px;" aria-label="Description: activate to sort column ascending" rowspan="1" colspan="1" jquery17208485980922457772="80"></th><th tabindex="0" title="Selling dealership quantity on hand" class="sorting" role="columnheader" aria-controls="orderSummaryTbl" style="width: 48px;" aria-label="QOH: activate to sort column ascending" rowspan="1" colspan="1" jquery17208485980922457772="81"></th><th tabindex="0" title="Selling dealership advertised discount on D2DLink" class="sorting" role="columnheader" aria-controls="orderSummaryTbl" style="width: 69px;" aria-label="Discount: activate to sort column ascending" rowspan="1" colspan="1" jquery17208485980922457772="82"></th><th tabindex="0" title="Selling dealership's phone number" class="alignLeft sorting" role="columnheader" aria-controls="orderSummaryTbl" style="width: 101px;" aria-label="Phone: activate to sort column ascending" rowspan="1" colspan="1" jquery17208485980922457772="83"></th><th tabindex="0" title="Quantity Requested" class="sorting" role="columnheader" aria-controls="orderSummaryTbl" style="width: 48px;" aria-label="Qty: activate to sort column ascending" rowspan="1" colspan="1" jquery17208485980922457772="84"></th><th class="sorting_disabled blankCell" role="columnheader" style="width: 20px; visibility: hidden;" aria-label="" rowspan="1" colspan="1"></th></tr><tbody id="orderSummaryBody" role="alert" aria-live="polite" aria-relevant="all"><tr class="odd"><td class="dataTables_empty" valign="top" colspan="8"></td></tr></tbody></table>
<table><tbody><tr valign="middle"><td> </td><td style="padding-left: 6px;">
<table><tbody><tr valign="middle"><td> </td><td style="padding-left: 6px;"> </td></tr></tbody></table>
B3TZ7A011A:
TCAA4676A:
This one is going to be long so I apologize in advance...
qman, Thanks a million for the part numbers. I went on a small rant to jefffafa little earlier over part stores NOT being able to help me get my parts. My son and i went back to O'reilly's and spent an hour and a half with a guy poking and measuring seals. Poor SOB...
Jefffafa, thank you much for the grocery list.
Ultra, thank you for the heads up. Because i'm a computer dumba$$, can ya throw a brother a part #? I'll be following qmans lead and ordering from rockauto. I can just give you my card # if ya want to order it for me too
I have my son looking at this FTE forum with me to get him hooked up. He has taught me too, dragging me into the 21st century using a stinking computer. We talked about hid name, should it be Sonof teachNlive4ever or TrollNtraining (TIT) LOL
More Information for TIMKEN 5203
....but, I prefer to deal with local parts stores, in the event something is wrong, it's much easier to take a part back to a local parts store than to have to box parts up and ship them back.
I would imagine an exact or, comparable, bushing/seal could be purchased from O'Reilly's or NAPA.
#28
"If you still have a Bump tranny with a Bump output shaft and a Bump driveshaft the trans output shaft"
Mine has the bolt bolt on flange on the out put shaft (pinion seal). I've seen them (FE C6) with a slip yoke.
Ultra, the part you sent me has a smaller diameter seal than mine, so I didn't order that part.
I agree 100% about buying parts you can touch and feel.
Does the c6 bolt on flange have an output shaft bushing? I know there is a gear that slides onto the shaft to operate the speedo.
#29
https://www.ford-trucks.com/forums/a...1&d=1433681532
