Think I made a BIG mistake with this Fiberglass, any "fiberglass guys" that can help???
First of all, this is a topper for my '05 F150. While not the right generation, I use this truck to experiment for stuff with my 56 "kind of" making it relevant.
For this deal I am experimenting with the DIY spray in liner on the underside of the fiberglass.
The issue:
I bought this topper for $150.00. It had been sitting on the ground and was dirty and molding/mildew. I flipped it upside down, hit it with some water, and some blue wolf degreaser. Scrubbed it with a brush and rinsed it out.
It looked great, like new! As it started to dry, it started leaching out in places. First a light tan, then these darker spots. I thought it was just water that had gotten behind some of the loose strands. I put a heater under it for TWO days, and it still continued to have moist patches, now I have had a fan under it as well for FOUR days. 6 Days of total dry time. The moisture level has went down but I am left with these "tacky/sticky" brown spots.
What are they? is it resin from the glass, something leaching out of the mdf or plywood use in the topper?
How do I clean it off? Think it is safe to spray with the liner now?
First of all, did you cut it 3 parts water to 1 part degreaser like it says for fiberglass?
It looks like the degreaser has had a chemical reaction with the fiberglass mat or resin. If you used it full strength, it may have been too strong and started to deteriorate the bond within the fiberglass.
Why not try spraying a small area to see what it does? Or does the liner need to be mixed all at once?
