What are all these wires, and why aren't they hooked up?
In doing some snooping around the truck, I've happened upon several wires that appear to be factory wires, and yet they're not hooked up to anything. I don't want to start cutting things out before I know what they are, but I want the engine bay de-cluttered as much as possible.
Received 3,090 Likes
on
first one comes off the battery negative terminal, and goes to the rad support rite? that is a body ground. it needs to be reconnected.
second one is the AC clutch power wires. you can see in the picture where it is unplugged on top of the compressor, rite behind the pulley.
third one i am not sure where it goes.
Thanks for the input, guys.
I got the ends replaced on the ground wire and hooked them up, but ran into a problem with the AC clutch wires. The retaining clip on the receptacle on top of the compressor has been broken off, so the plug doesn't snap into place. Is that something that can be replaced without disassembling the pulley and compressor?
on
on
reebadoo
11-05-2018 10:20 PM
Jarrett Campbell
05-13-2016 10:22 AM
460 FORD MAN
22
08-10-2012 04:34 PM
