Dana 70 Disc Brake Kit Came Today
Old 06-05-2015, 08:28 PM
Jssec's Avatar
Jssec
Jssec is offline
Dana 70 Disc Brake Kit from RuffStuff says it has everything but the brake fluid. Be installing on 1978 F350 CS and loose the shoes.
Old 06-05-2015, 10:26 PM
Jdeshler's Avatar
Jdeshler
Jdeshler is offline
Looks like a quality kit
Old 06-05-2015, 10:46 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Provisions for a parking brake???
Old 06-06-2015, 07:30 AM
Jssec's Avatar
Jssec
Jssec is offline
No Parking Brake Included
No parking brake - One kit out their has parking brake with it but its twice as much as this one $800 vs $328. Will use the extra $400 to install a Mico lock with my rear mounted winch parking brake would not hold it anyway.
Old 06-06-2015, 04:18 PM
Jssec's Avatar
Jssec
Jssec is offline
Well the 1st thing I learned is the center of the kit rotors are 5" diameter and the Dana 70 hub requires a 5 1/4" center don't know why Ruffstuff wouldn't have them turned before shipping. When I called them they said no one makes a 5" rotor opening so I would have to have them turned. Will make it work but may be last thing I buy from them.
Old 06-06-2015, 06:19 PM
HIO Silver's Avatar
HIO Silver
Your blaming RuffStuff is misplaced..... It shouldn't have been surprise because RuffStuff clearly states that the rotors need to be machined right on their webpage for that kit.
Dana 70 Ford Axle Disc Brake Kit - RuffStuff Specialties
"This is the bracket for your Ford D70 & D70U, it actually fits! I developed these after the success of our 14 Bolt brackets and seeing what was available on the market and the problems associated with the others. The D70 was used by all of the Big 3 automakers at one time or another and they all had different uses and designs specifically for them. These are for a Ford D70 or D70U only!
We have been making the brackets for a long time now with complete success so why not make the complete swap kit! These also use the '75 Chevy 3/4 Ton Front Rotors and Calipers and those really cost peanuts but the rotor will need the throat opened by ~3/16".
Old 07-25-2016, 08:18 PM
mse871859949's Avatar
mse871859949
mse871859949 is offline
Sorry to drag this up, I'm doing a disc brake conversion of my 77 f350. I got my kit from diy4x. I do not have clearance for the caliper. it's not even close. Did you have any issues? could you post some pictures? I don't even think a 2" spacer would help. I'm running 16.5" rims. Thanks!
Old 07-26-2016, 08:24 PM
gemutlich's Avatar
gemutlich
gemutlich is offline
OP hasn't been on here since April, you may want to send him an email or PM through the site.
Old 09-06-2016, 11:10 PM
WordFliesNverted's Avatar
WordFliesNverted
WordFliesNverted is offline
bump.
Did you figure out your caliper spacing issue on the diy4x?
1972fordhighboy2
10-23-2015 10:05 PM
big3g
03-08-2012 04:14 AM
xach
Offroad & 4x4
08-27-2002 05:34 PM
Quick Reply: Dana 70 Disc Brake Kit Came Today
