Need Advise on '07 Front Conversion Assembly
Ok, So I basically sold all my old '99 parts right off my truck getting ready for the swap.
I have installed the '07 Header (mount) panel w/o problems.
I have installed the '07 OEM headlights w/o problems.
I have installed the (used) OEM grille (with new billet inserts) w/o problems.
I have now hit a snag that I'm in hopes that someone here can help me with:
I bought an aftermarket chrome bumper, Pad, lower valance, brackets, fog lights......
I even bought the pad pre-painted from a seller on Ebay, which I may add came out outstanding!!
I felt as I needed to pre-assemble the bumper and all its trim before installing it all in one piece onto my truck.
I Installed the brackets which fir fine (I'm not sure yet if I have the hole in my frame for the side brackets, but I've got them and will try to install!
I installed the front tag bracket using 2 larger push pins as FORD had NO clue what they were attached with from the factory!
I installed the fog lights (mistake #1) -I found that the positioning pin in the center that sticks through the bumper WOULD NOT allow the PAD to come down flush onto the top edge of the bumper, so I had to remove the fog lights.
NOW, I STILL can't get the darn pad (with its energy absorber attached) to lock in fully (the little tabs will stick through but no matter how hard I push they won't go through far enough to lock in)........Any ideas on this?? I'm thinking most who have done this swap have just removed a complete setup from a donor truck and didn't have to worry about this part..........
Also, 1 more observation/question: MY truck has never had TOW HOOKS, and I an NOT installing any now, MY old bumper setup HAD plastic "block off plates" to cover the hole where the hooks would have been mounted--ARE there the same type of plastic plates made for the '07 bumper brackets?
Sorry for the long read guys, just wanted to give a back ground as to what I've done and where I'm at.
Thanks!! -Rick
Thanks!! -Rick
MemOrex
07-31-2004 08:41 PM
