30-40 Percent load at idle. Is this normal?
Haven't seen many threads on this topic. But what is a "normal" number people see on their load factor? Mine was around 25-30 a few weeks ago but I noticed it is increasing to around 30-40 once I'm in gear, in park it's fine. My acceleration is also getting a bit sluggish too especially going up hills and my throttle isn't responding all the way, my turbo boost is normal though and I don't think there is any VGT stiction. I'm thinking either a fuel filter or a MAF sensor to start with. Fuel filters have been in exactly 10 months. Can a dirty fuel filter, air filter, or MAF sensor affect engine load at idle and how fast it accelerates? I feel like I'm pulling a trailer and with it being more sluggish, my transmission is shifting harder as well.
Thanks
Thanks
If your in doubt of the filters performance, change it... period. Isn't worth messing around with a $15k engine for a cheap, under $50 filter. I change oil filters about every 3k and oil every 6k or so. The fuel filter gets it every other oil change.
I remember seeing around the same numbers for LD, somewhere around 30-40.
Air filter is a 100K filter, but changing it shouldn't be a major decision, early is better.
As for slow response, what are some of your live data saying? ICP, IPR, FICM voltage and main power?
Clean the MAF and EBP sensors, easy to do and may be the cause of lagging power.
I'm on my cell so I can't see if you have a signature or not, what year truck?
EBP sensor 03-04 is near the thermostat, right side and the bracket is bolted to the t-stat housing. 05 and up is under the air filter area and comes out of the manifold, right side. Clean it with string trimmer line, the tube that is.
MAF is on the passenger side mounted to the fire wall near the A/C stuff and the tube goes down toward the lower part of the left side.
Ok so my throttle response is worse by the day. I pulled the intake vacuum hose off the nipple it was on and found it torn and chafed where it was clamped on. I drove to autozone (another vehicle) and of course they wouldn't have the size ford uses so I got one the next size bigger. It was way too big so I'm gonna down size tomorrow. There was also some gooey stuff down in there which could have clogged and caused a false reading. I saw a YouTube video about it and my truck is showing the same symptoms.
If so it is 1/4" but 7/32" works too.
Just another thought on the subject. Whenever the subject of the value for %load comes up, one of our Techs here (I forget who) has repeatedly pointed out that the value displayed only exists so the PCM can complete other calculations and shouldn't be considered an accurate measure of load. That is to say it's the product of one operation embedded in a calculation.
In other words it may be of some limited use in very particular circumstances but should be considered a relative value and the actual number should be taken with a large grain of salt. It ain't right, but it serves it's purpose.
Ok everyone it is sluggish again. Can't seem to figure it out. Only thing I can think of is it can use new tranny fluid/filter or I have low compression/bad injectors. My turbo veins aren't sticking as I'm watching my VGT% and all seems normal with that. Same with FICM, all is normal. I couldn't really get to the EBP sensor. I need some pointers on that as well as other things I haven't looked at.
