trans fluid tytpe? and change question
#46
#47
#48
#49
It must have the updated TC (from the 6.0 powerstrokes)
I dont know if this is the right process of draining the tranny fluid, but on the chettys 2500 there is no drain plug, so removal of pan is necessary but I found it easier just to unhook the return line from the trans cooler start her up and let it drain completly and keep adding new fluid till it comes out red/clean hook it back up, add fluid and call it a day. Not sure its the right way but has worked great with these trucks and no problem most over 250k one even has 400k on a stock tranny.
1Austin112
09-22-2015 05:15 PM
granny_rocket
05-10-2015 04:49 PM
