Help! Identify these heads!
Old 06-05-2015, 01:12 PM
Resurrected 56 F100's Avatar
Resurrected 56 F100
Resurrected 56 F100 is offline
There are no casting numbers on my heads as the numerous websites have shown. I've only found "73B", a "G" and a "15". The valves are the larger 1.92" size. Are these the ECZ-G heads?
Old 06-05-2015, 04:02 PM
charliemccraney's Avatar
charliemccraney
charliemccraney is offline
The numbers will be on the heads somewhere. Make sure it is clean, use a light, and magnifying glass, if necessary.
I'm pretty sure that is a G head.
Old 06-05-2015, 04:23 PM
Resurrected 56 F100
I guess its time to pull out the 'ole drill and wire brush.
Old 06-05-2015, 10:55 PM
hiball3985's Avatar
hiball3985
hiball3985 is offline
It looks like a G head. The casting numbers are usually on the intake port side of the head at one end..
Old 06-12-2015, 10:54 AM
Resurrected 56 F100
I found the casting number! It's ECZ-G. Aren't these fairly desirable heads? I like the fact that they have the bigger valves. Now I wish I knew if these were '57 or '58...
Old 06-12-2015, 11:18 AM
charliemccraney
They are among the best factory heads for the Y.
I'm rusty on date codes, but I think the 73 and backwards B is the date code, so 1957 (7) March (3) 26 (backwards B). The letter corresponds to the day of the month, excluding I and O for confusion, that's 24 days and the backwards letter indicates that the count started over, so 24 + 2 (B) is 26.
The date doesn't matter much, unless you are trying to build a vehicle to be as correct as possible and these are not correct if they are for a 56 F100.
Old 06-12-2015, 01:33 PM
Resurrected 56 F100
Nice! No, not trying to be correct, just trying to find the most accurate specs for this engine. Thanks for explaining the 73 B.
My dad and grandpa actually swapped this engine in to replace the 272 back in '69 or '70.
Old 07-29-2015, 12:08 AM
sawmaned's Avatar
sawmaned
sawmaned is offline
heads
are those heads off a thunder bird 292
Old 09-03-2015, 04:19 PM
312's Avatar
312
312 is offline
all 57 engines used g heads.theres no such thing as tbird heads.they used the same heads as ford.
gearhed1971
12-04-2008 05:58 PM
job1bf
01-08-2007 11:29 PM
Bonkrr
09-14-2006 09:23 AM
fordraceboy
16
11-07-2005 09:29 PM
DGMFORD
12-21-2004 06:42 AM
Quick Reply: Help! Identify these heads!
