1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
7.3 cranks good . fires but very hard start
Old 06-03-2015, 05:20 PM
leanmechanic's Avatar
leanmechanic
leanmechanic is offline
Dealing with a 02 f350 7.3 powerstroke . The engine cranks fine . It fires but won't start smoke coming from exhaust while cranking and firing so seems to have good fuel . When it does start it misses for a few minutes and blue/white smoke . When the miss ends so does the smoke and starts fine after that and runs great until it sits for 12 or more hrs . Then back to same start issues . Fresh oil ,new glow plugs, new cover gaskets , glow plugs test at 1.3 ohm across all 8 of them , no voltage drop through glow plug relay , good voltage to each glow plug when tested right at glow plug terminal on each feed right at glow plug , fuel filter housing stays full doesn't seem to bleed back , high pressure oil pump pressure test was high enough to trash a 1000 lbs gauge in 2 to 3 revalutions of engine when cranking . Tested at presure sensor port . Let the brain tease begin for you all . I hope someone might have an idea of what ghost to chase next ..any help would be appreciated ..
Old 06-03-2015, 05:23 PM
leanmechanic
Originally Posted by leanmechanic
Dealing with a 02 f350 7.3 powerstroke . The engine cranks fine . It fires but won't start smoke coming from exhaust while cranking and firing so seems to have good fuel . When it does start it misses for a few minutes and blue/white smoke . When the miss ends so does the smoke and starts fine after that and runs great until it sits for 12 or more hr8s . Then back to same start issues . Fresh oil ,new glow plugs, new cover gaskets , glow plugs test at 1.3 ohm across all 8 of them , no voltage drop through glow plug relay , good voltage to each glow plug when tested right at glow plug terminal on each feed right at glow plug , fuel filter housing stays full doesn't seem to bleed back , high pressure oil pump pressure test was high enough to trash a 1000 lbs gauge in 2 to 3 revalutions of engine when cranking . Tested at presure sensor port . Let the brain tease begin for you all . I hope someone might have an idea of what ghost to chase next ..any help would be appreciated ..
The engine has 418000 km on it .
Old 06-03-2015, 07:12 PM
92f150I6's Avatar
92f150I6
92f150I6 is offline
possible problem with the fuel heater element maybe? Might me something to check.
99whiteford
04-06-2018 11:41 PM
skoto1
18
05-07-2016 09:47 PM
RolnCl
01-11-2015 07:17 PM
mozzles
10-22-2012 08:33 PM
Vimuise
09-24-2012 06:49 PM
Quick Reply: 7.3 cranks good . fires but very hard start
