Help with suspension - 2011 F-250
I'm a total newb and overwhelmed at all the options for these trucks. I've searched and read about every thread and now more confused.
I just bought a 2011 F-250 CC SB 6.2 FX4. 190K miles. It has Rancho shocks, which I believe are still original LOL. The truck has a very rough and bouncy drive. Steering wheel is a little off centered. I've driven a 2004 F-250 6.0L FX4 and it also rides like crap, but it too has factory rancho shocks. So I really have nothing else to compare to.
Got a quote from 4 Wheel Parts to put in new Bilstein level kit #F4-SE5-C765-H0 (shocks and springs w/ 2" front lift), and Bilstein 5100 shocks in rear. I believe the rear included a spacer, but not sure. Alignment. $960 out the door. $360 in labor, $80 for alighnment. Rest for Bilstein parts. Not unreasonable.
I am going to tow a 7500# Travel Trailer. I will have a weight distribution hitch. I don't want it sagging, hate the look for a sagging rear end! Should I put in air bags?
I just measured fenders to the ground, rear end is just under 1" higher. Looks level to the eye. Front is 39 3/4" and rear is 40 3/4".
My options are the following:
1. Keep ride height same. Replace shocks with new Bilstein 5100 on each corner. Replace steering damper with Bilstein. Do I need to replace stock springs at 190K miles or are they fine?
2. Put in 2" Bilstein level kit and Bilstein 5100 shocks front/rear. and get rear to not sag somehow.
I'm leaning towards not lifting and getting the largest 18" wheel/tire I can fit without rubbing and get a much better look. Replace shocks with Bilstein 5100s on each corner and the steering damper. Should I leave factory springs in the front?
Ugh, what would you do?
Pic of truck:
Pic of truck:
I did 3" lift on my 2011 but didn't like back height so I got talked into bags. Recently installed helper spring instead. The biggest problem with airbags is it stiffens the ride when aired tight (think haywagon).
I definitely need something to keep the rear from sagging. Camping World tech installed my Equalizer hitch, said it was setup correctly. I'll play with it and see if I can get it better. The rear went down 1" and front stayed about the same. Not sure what tongue weight is, will find out in a week when I can get my hands on a scale. Trailer had 2/3 tank of fresh water a few feet from front.
Are airbags my best bet? Or is there a better option?
I have a 4" Zone lift on my 2014 and my front sets about 1/2" higher than rear. I have been looking at ways to fix that either add-a-leaf, air bags or helper spring pack. I was leaning toward airbags till I read your reply. Do u have a helper spring pack or add-a-leaf and how does it ride now? Thanks
The squat when towing is really annoying me. I hooked up my TT this weekend without the equalizer hitch and it bucked quite a bit on my 15 mile drive.
I'm leaning towards adding a leaf. Which kit? I talked to a guy at 4 wheel parts on the phone and he didn't sound like he knew his stuff. He said it's around $250 for each spring, pro comps. Sound right, $500 for the rear?
If I do a add a leaf, do I keep the front stock height or add a level kit (2")?
I'm digging the Timbren SES kit. Cheap and easy to install.
Help me out if I want to do a level kit.... Here is what I'm thinking:
FRONT:
- Bilstein Level Kit (2") #F4-SE5-C765-H0: Includes new springs and Bilstein 5100 shocks
REAR:
- Bilstein shocks
Looks like my options are:
- Add-a-leaf + Timbrens. Would this keep the truck level with the 2" front lift?
- Add Ready Lift 4" (2" lift) + Timbrens
FRONT:
REAR:
- Bilstein shocks
I have the same problem with my 2012 f250 and I have the camper package which is basically the f350 springs. The total lack of any rack is the issue my truck handles weight perfect it just looks silly loaded up. I just ordered the ready lift 4" rear block kit specifically for f250's kit #66-2014. I'm still waiting for them to arrive but I'm hoping to have it sit like the f350 when done which will solve my issue. It's still going to sit on the overloads(as would a f350) but it will sit more level loaded due to the added rake. I didn't do air bags because I don't want the ride to get any stiffer empty or need to fill/deflate bags every time ( I'm far to cheap for a built in compressor). I can't wait to get these in.
The ready lift block is 4" but you need to remove the factory 2" block so it's really an increase of 2" above stock. I read some posts that say shocks are not required and others say they are so I will figure out if there is enough extra length when I install the blocks. I may or may not also need to change out my rear sway bar end links but I'm not sure the extra 2" will effect it enough to worry about those links. I'm not sure if yours has the camper pkg which comes with the rear stabilizer bar so might not be an issue for you. My truck sits nose high stock due to the heavier front springs and when I'm even lightly loaded it looks sagged. Look the ready lift kit up (66-2014) it seems reasonably priced and I'm hoping for a quick install since nothing is all rusted together on this truck.
Ok, that helps.
My rear end sits about 1" higher. I am thinking the Bilstein front kit and ReadyLift 4" blocks will get me a nice 2" lift. Now need to see if the Bilstein 5100 shocks will work with this or I need a different shock with the 2" increase in lift. I also think I'll put in Timbrens to keep it level when loaded down.
Sound like a good plan??
